Author Topic: Alitum 14 CAMtastic errors  (Read 1462 times)
Offline SparkFlyTopic starter
« on: November 06, 2017, 07:18:53 pm »
I'm working on a design (excuse messy areas) and was curious as to what the final gerber outputs would look like. I went through Alitum 14's Gerber generator and viewed the top copper layer (.GTL) in CAMtastic. However I notice that it seems to have duplicated other component layers, such as top silkscreen, on this layer too! I noticed that this only occurred on layers built using the IPC compliant wizard tool. I've attached an example below.
Is this a simple rendering bug? I've noticed the viewer isn't terribly great. Or is this a 'real' problem?
Many thanks for your time help, I appreciate it very much.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Alitum 14 CAMtastic errors
« Reply #1 on: November 06, 2017, 07:33:23 pm »
Uh, well, didja check the library if it actually looks like that or what? ???  'Cuz once it's generated, it's just another library.
Seven Transistor Labs, LLC
« Reply #2 on: November 06, 2017, 07:50:19 pm »
I've just figured it out... Should've held fire on the forum post... Apologies.
Turns out I shouldn't asked it to plot mechanical layers. Everything looks good now.
Thanks for the reply all the same T3sl4co1l.
