the problem is i cannot get all the parts into the circuit in LTSpice, and i dont see anywhere to do spice modeling.
It is described in the build-in help, in the, *drum rolle*, FAQ section
LTspice supports a lot of PSPICE extensions, making it typically very easy to use third party modes and subcircuits.
and the sim with fix timeline is quite PITA for me.
What simulation? LTspice does all the classic SPICE simulation types. Use
Simulate -> Edit Simulation to select the type of simulation and configure it.
There are IMHO things wrong with LTspice, but these aren't. One thing that is wrong with it is that it has a lot of hidden features. There is, for example, since a vew versions a feature for automatic symbol generation. The documentation of this feature is just two sentences, and these aren't very helpful. Granted, the generated symbols don't look great (just boxes with pin numbers), but they spare you a bunch of work in the symbol editor.
Other features, especially in those in the graphics display aren't documented at all.
any comment about this tina?
Just another SPICE.
My issue with all these SPICE versions is that they do exist ...
Every Tom, Dick and Harry (this includes Linear with LTspice), sees the need to come up with on own SPICE. All slightly incompatible and with proprietary extensions. Since decades I wish the industry would form an industry organization for developing and standardizing the SPICE language. That organization should publish a reference implementation, too.
Such corporation among competitors works in other areas. Standardization organizations aren't unheard of in the electronics industry
But when it comes to SPICE every company things it is more clever to invest in an own SPICE version and to re-invent the wheel. This is even more unfortunate, because the ancestor of most, if not all of these SPICE versions is the open-source SPICE code from the UCB.
