hello,
I'm moving from Eagle to Altium and I'm trying to set the Altium's user interface similary to Eagle's. I've set the zoom command for using with mouse wheel correctly, but I have a problem to set rotate component command. In Eagle I was using right mouse click to component rotate.
Is it possible to set this command in the same way as in Eagle, please? Because in Altium's Edit-Move-Rotate selection I can only choose keyboard shortcuts...
Thanks,
Peter
