Author Topic: Altium Designer component mess when importing to PCB  (Read 665 times)
Offline trio36
« on: February 01, 2018, 04:47:00 am »
Hello.
I am having this issue when "importing changes" into my PCB.
Components from one specific sheet will create a huge room with very high separation between the components.
Identical components are used in the other sheets and they do not seem to have this issue. Also I tried to copy the contents of the problematic sheet into another schematic document. That did not help.
Thank you.
Offline D3f1ant
  • Doing as little as possible, but no less.
Re: Altium Designer component mess when importing to PCB
« Reply #1 on: February 01, 2018, 06:23:37 am »
I've had this too at times, I think it's somewhat random and been a problem through many versions of AD. What version of AD? I don't recall seeing it for a while.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: February 01, 2018, 07:30:24 am »
Hm, usually it goes the other direction (imports in a single row, not a column).
Easily enough fixed: select all in room, T, O, L, select two corners of a rectangle, done.
Seven Transistor Labs, LLC
