1) OK, pressing F1 is a good solution. Thanks marshallh! Command status is also a good tip, free_electron.
2) I have a Thinkpad W series laptop with 1920x1080 resolution in addition to a desktop workstation. I'd like to be at least semi-productive when I'm not sitting at a workstation.
Even when working at a desktop computer, setting the default shortcuts for Next Layer and Previous layer, which are two of the most-used shortcuts, to be numpad-centric does not make any sense in terms of economy of motion and ergonomics. The numpad is at the opposite end of the keyboard to all the other shortcuts associated with Interactive Routing and the rest of the program operation in general. I checked out the PCB Shortcuts button you described, free_electron, but couldn't find any way to change the shortcut keys within the Interactive routing mode. If there is no way to change them, I'll live, but its not ideal.
3) The L key functionality outside of Interactive Routing works as you described, free_electron - thanks! What does L do while you're in Interactive Routing, though? I can't get it to do anything except make a bell sound.
Here is a picture: I am in Interactive Routing, I pressed tilde, which brings up the available options. I can't get Switch Layer for Current Trace to do anything.
Control-clicking on the available commands in an
attempt to customize them doesn't work.
