First, compile the project, make sure there isn't schematic issues, import changes from the project to the pcb, execute the ECO, make sure the drc rule for unrouted nets is enabled, then run DRC.
The compiling the project isn't strictly needed if you just tweak the schematic. And if you've been adding and removing components, check the component links to make sure all pcb components are linked to schematic components.
