Anyone can try this. create a new schematic document (everything default) and pick up a transistor from the default libraries. You can not align all pins to the grids at the same time!
actually, this can be tested with any component that its pins are not straight aligned such as a resistor, a diode ...
try headers, Potentiometer, mosfet, transistor and similar ...
