Author Topic: Anybody still using Protel PCB 2.8?  (Read 13567 times)
Offline peter-hTopic starter
« on: October 17, 2017, 01:26:06 pm »
This is a great package, 1995 vintage, which I still use, under windows XP (doesn't work under win7-64).
It does all I need and has almost no bugs. It takes netlists from Orcad SDT/386 which also works great under XP, using the GDI drivers.
Was there ever a successor which retains the functionality without introducing massive bloat?
Protel got taken over by various companies afterwards. They did a PCB v3 but from what I saw it was full of bugs and barely usable. It had Orcad SDT schematic import but the result was rubbish, with components moved around etc.
The PCB 2.8 I have, GBP 1500 at the time, is a legit copy. It was dongled originally.
I had the Altium salesman on the phone a while ago, pushing a GBP 20k product. I told him we still use PCB 2.8 so don't need it. He dropped the price to 10k and later to 5k. But I know that program would take me a year to learn and probably still is full of bugs. They also run the floating license locking system where if the license server breaks you can't use the program anymore. There was some way to build a duplicate license server for that case, by cloning the MAC of the server's ethernet card, but it is still a hassle.
Offline HighVoltage
Re: Anybody still using Protel PCB 2.8?
« Reply #1 on: October 17, 2017, 01:38:36 pm »
I still have my copy of Protel PCB 2.x (Not sure which version was my last one) somewhere in a box, but have not used it in 15+ years.
IIRC, the dongle was on a parallel port, did you add the parallel port to your XP machine or did you bypass the dongle?
It will probably run on a Win7 with a virtual XP running inside the Win 7 OS.
« Reply #2 on: October 17, 2017, 03:14:25 pm »
The dongle was bypassed. It is a simple patch of the .exe. This was necessary on all the software of that era, as the vendors vanished.
I still have the parallel printer ports, but that isn't the problem.
For example I used to do Xilinx FPGA design (X3000 mainly) and there were two dongles - one for Viewlogic/LCA and one for XACT. Both eventually failed (they broke) and Xilinx wanted ~$20k for the later tools. I stopped doing that work in the late 1990s anyway. Too much hassle, with newer tools not importing older designs. The Xilinx sales guy just said you have to crack some eggs to make an omelette :) So you had to archive the old tools, the old computer and the dongles :)
Yes; Protel PCB 2.8 does run nicely under VMware, winXP VM. I had some trouble with the mouse functionality; there is an obscure config in the VMware mouse properties which fixed it.
It's a good Q whether Protel ever did a more recent (but largely bug-free) PCB package which imported the v2.8 PCB files.
« Last Edit: October 17, 2017, 03:16:36 pm by peter-h »
Offline jmarkwolf
« Reply #3 on: October 19, 2017, 04:47:20 pm »
That's the version I started using along about 1996, been using Protel/Altium products ever since.
Still have a warm spot in my heart for Protel 99SE. Would still be using that if it ran under current O.S.'s.
Offline Warhawk
    • Personal resume
« Reply #4 on: October 20, 2017, 08:16:02 am »
You can make Protel 99SE running in Windows 7, maybe also in W8 and 10. You can find more information here: https://www.eevblog.com/forum/eda/free-trial-of-protel-99se/
and here: http://www.diyaudio.com/forums/software-tools/51279-loading-library-file-protel-99-a-3.html
I tested it some time ago and it worked.  ;)
Offline capt bullshot
« Reply #5 on: October 20, 2017, 09:06:47 am »
I still have a copy of Protel 98 around, some half year ago I installed it on a Win7 PC. No dongle, just a serial number to enter, it just worked. I had to view an old project, didn't do any serious work on it, but rememered pretty quick all the keyboard shortcuts. I really liked them back then, left hand at the keyboard, right hand at the mouse all the time, very efficient to use. And it could import older (2.8 or whatever) projects.
« Last Edit: October 20, 2017, 09:08:48 am by capt bullshot »
Offline EEVblog
« Reply #6 on: October 20, 2017, 09:42:06 am »
When I was working at Altium circa 2011 half of China and countless others were still using the 12 year old 99SE.
The sales people would always complain how it was to convince people to switch. Tons are probably still using it.
Offline Circlotron
« Reply #7 on: October 20, 2017, 10:00:03 am »
I would like to get a copy of 99SE so I don't have to do stuff on work's computer. PM me if you have one available.
Offline Circlotron
« Reply #8 on: October 20, 2017, 10:28:00 am »
If that's the case, maybe there should be a forum sub section for 99SE instead of  getting lumped in with Altium Designer stuff?
« Last Edit: October 20, 2017, 10:58:00 am by Circlotron »
« Reply #9 on: October 20, 2017, 10:41:07 am »
So why should they want to switch - the new Altium designer costs a wealth of money and has a steep learning curve. IMO Protel 98 / 99SE was very efficient to use once you got used to it and provided everything you need for your job to be done, no support required - so I don't see a reason to switch. Protel was simply to good for this world :-)
Online DrGeoff
    • AXT Systems
« Reply #10 on: October 20, 2017, 10:48:14 am »
Still use it. On Win 10.
Was it really supposed to do that?
Offline jmarkwolf
« Reply #11 on: October 20, 2017, 11:21:50 am »
How so?
Online DrGeoff
    • AXT Systems
« Reply #12 on: October 20, 2017, 11:26:17 am »
How so?
It just works when run under compatibility mode for WinXPsp3.
Still have all my libraries developed over the last 15 years or so. Never had a problem with it.
Offline Warhawk
    • Personal resume
« Reply #13 on: October 20, 2017, 12:36:18 pm »
How so?
I sent you two links how to make it running few posts ago  ;)
Offline EEVblog
« Reply #14 on: October 20, 2017, 01:08:08 pm »
Bingo, that's what everyone thought, and why it was so hard to get people to switch. They took a look at Altium Designer and didn't see much added value, and also saw all the silly direction they were headed with FPGA's, making the PCB optional extra, the Summer/Winter confusion etc and customers just rolled their eyes and went back to 99SE. It was an industry standard for 10-15 years which is quite amazing.
Offline mairo
« Reply #15 on: October 21, 2017, 09:14:06 pm »
To switch from 99SE to the current Altium, one pretty much needs to buy the full price software (which people should be able to bargain down to 50%-70% of the advertised price), so as others have said already, not too much added value, but I think if Altium offers those users the switch at just the price of the yearly subscription (+ maybe a free online training course) , some people may do the switch.
Online DrGeoff
    • AXT Systems
« Reply #16 on: October 22, 2017, 02:27:12 am »
Pay more to do the same. No thanks.
« Reply #17 on: October 23, 2017, 03:26:37 pm »
How well did 99SE import the v2.8 .pcb files an libraries?
« Reply #18 on: October 23, 2017, 07:11:11 pm »
I don't remember details, and I don't remember any particular problems, so I think it was OK and usable.
Offline jmarkwolf
« Reply #19 on: October 24, 2017, 11:13:50 am »
Same here.
Offline snoopy
    • Analog Precision
« Reply #20 on: October 25, 2017, 11:40:16 pm »
Not only that Altium got so desperate, they made an ad targeting existing users of Protel 99SE and why they should upgrade to Altium by bagging the crap out of their own 99SE product to get their point across ;)
The trouble is they made 99SE to well and more than adequate for 90% of pcb jobs so I am not surprised there are still a lot of people still using it ;)
« Last Edit: October 26, 2017, 02:28:23 am by snoopy »
Offline jmelson
« Reply #21 on: October 27, 2017, 10:33:13 pm »
Protel 95 and Protel 98 were horrible!  Protel 99 showed promise.  Protel 99SE with SP6 was really good.  There are about 5, maybe, bugs there, but it is pretty easy to avoid them.  Most important to me, is that the schematic checks have only one bug (if you have the same pin number twice on a component, it fouls up the net generation and rules checks.)  Other than that, the number of goofs it detects in multi-page schematics seems to be 100%.  And, the DRC on the PCB seems to be 100%.  I've done 200+ boards with it so far, up to 6 layer.  If the board doesn't work, the schematic is just wrong, and no EDA tool can fix that!
If you can get a copy of Protel 99SE with SP6, I think you will find it is an extension/improvement over Protel schematic and PCB, with much the same flavor.  it does have editable shortcuts and menu selections, which I have customized a bit.  I no longer remember the areas that got improved/extended, but they seemed to be good and logical places to add features, not stupid fluff.  I know that I asked for a number of these.
For history, Accel was the US distributor of the Protel products.  Accel was getting pressure to add stuff, and rewrote the basic functionality of Protel's product in (I think, C) and pushed it out.  That was Protel 95, so totally unusable it was a VERY bad joke.  They had to backpedal rapidly, and eventually Protel bought them out and brought their more well-reasoned software development strategy to bear.  Not sure if Protel 98 was also Accel's C-language effort, or was migrated to Delphi.  Protel 99 was in Delphi, but was a relatively new program, and needed to get the bugs out, that was the 99SE version.  (I think I've got this history mostly right...)
Anyway, Protel doesn't want to give away their old Protel99 program, as it will do 90+% of what Altium Designer will do.
I still run P99SE, using VirtualBox on a Linux host.  Your choice of Win 2K, XP or 7.
Jon
Offline b_force
    • One World Concepts
« Reply #22 on: October 27, 2017, 11:04:06 pm »
I can also totally agree with this.
It happens to often that companies just totally destroy a winning team. Most of them go all overboard all of a sudden.
I never understood why they had to make all kinds of new additions and extra's, except for a decent 3D design (which is not even mandatory in many cases)
BTW, diptrace seems heavily modeled around the older Protel versions, really feels similar.
Offline DerekG
  • Country: nf
« Reply #23 on: October 28, 2017, 01:51:22 am »
The reason for this is because a dozen or so Altium users (& several PCAD users) believe that Protel was in many respects a better PCB design platform than Altium Designer. They have been working hard with the DipTrace Design Team to implement the better features of both Protel & AD into the later releases of DipTrace.
DipTrace 3.0 offered so much more than the old Protel product whilst still retaining the easy-to-learn & easy-to-use user interface.
And DipTrace 3.2 was released just yesterday :)
I only use Altium Designer now when re-working legacy boards.
DipTrace 3.3 will have a push & shove router .......... another feature that can be ticked off the Altium wish list.
I also sat between Elvis & Bigfoot on the UFO.
Offline b_force
« Reply #24 on: October 28, 2017, 11:07:49 am »
Interesting. I wasn't really satisfied with the older version of diptrace, but the new version seems to work pretty good actually.
Hopefully the makers are reading along, because I am missing some almost mayor issues like keyboard shortcuts (like mirroring) and as well as the ability to change a whole range of values/footprints (which is a must have with big boards).
How good is the PADS import feature with older PADS boards? If that works smoothless it's really a win for us. Because a lot of designs are still in the old PADS format.
