Author Topic: "smash" in Altium?  (Read 1599 times)
Offline kortsleting
  • Country: id
"smash" in Altium?
« on: June 21, 2016, 08:38:02 pm »
I tried searching but if this is a repeat, my apologies.
Is there something like smash component in altium? I am working on a schematic and the part name (and value) is clobbering a component next to it. I would like to move them (name and value) somewhere else. Can someone point me to the right direction?
Also, is it the same process in PCB?
Thanks
Korts.
Offline ebclr
Re: "smash" in Altium?
« Reply #1 on: June 21, 2016, 09:14:02 pm »
Just click right muse click properties chose where you want to be anything
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: June 22, 2016, 03:37:28 am »
You can always click and drag the designator or comment or other label, wherever you want.  If you want it autopositioned, you can set that as well (double-click the part or the designator, or select multiple designators and do it from the inspector).
Not sure what "clobber" and "smash" mean in this context; example pictures would be helpful. :)
Seven Transistor Labs, LLC
Bringing a project to life? We can help.
Offline kortsleting
  • Country: id
« Reply #3 on: June 23, 2016, 11:37:05 am »
Thanks everyone, looks like I need to do the grunt work of reading and trying myself (what's the other way?).
Tim, "smash" is a very Eagle term. This is where we separate the component from its name/value; therefore we can move name/value anywhere in our workspace. Example of my problem (taken anywhere else from the web to give an example)
You can see the names of some parts are intruding into other parts. In my case, the problem occurs when I am drawing electrical schematics. Thus my original post.
Clobbering? I thought that was regular English...  :D
« Last Edit: June 23, 2016, 11:40:35 am by kortsleting »
Offline blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #4 on: June 23, 2016, 11:40:14 am »
In Altium you do not have to "smash" parts. Labels and bodies are already not tied together.
Offline ebclr
« Reply #5 on: June 23, 2016, 07:30:03 pm »
Simple click on the name and move anywhere you want, simple as that
Offline kortsleting
  • Country: id
« Reply #6 on: June 23, 2016, 08:20:51 pm »
 :D
Excellent. Thanks guys.
