Author Topic: Autorouter problem  (Read 1673 times)
Offline meerwetenTopic starter
    • Greendigit Electronics
Autorouter problem
« on: June 10, 2017, 07:13:36 pm »
Hi all,
i'm having problems with the autorouter.
well actualy it isn't working at all.
when i start the autorouter it put out the lines in the picture but thats it.
any one here knows a solution?
ps.: yes i don't like autorouting, but sometimes its needed when there is no real time to rout a board for test (eg a pcb for production testing)
ps2.: i actualy never got the autorouter to work if that helps
Meerweten, Want meten is Weten
Offline free_electron
    • SiliconValleyGarage
Re: Autorouter problem
« Reply #1 on: June 13, 2017, 03:20:55 pm »
did you configure the router ?
you need to set it up ... make sure there are rules for it to follow and that it knows what to do. just clicking 'run' produces nothing.
The following users thanked this post: meerweten
« Reply #2 on: June 13, 2017, 06:32:45 pm »
well that might just be it thanks  |O
better find a tutorial for it  |O
