I have created an opamp library.
I use it in the circuit without any problem.
However, if I rotate or flip the opamp vertically, its power pins and their text labels also change location.
In a standard opamp symbol, the positive voltage pin is always on the top, and the negative voltage pin is always on the bottom. How do I keep these pins and text labels always in their originally defined locations.
