Huh, I never noticed that before. Do you use grid 1 (or, god forbid, no grid at all) a lot??
I suppose my workflow is: 1. place components roughly, then wire them (Place/Wire snaps to pins); 2. snap objects to, and drag components with, large (10) grid, so nothing comes apart; drag makes it obvious which wires are connected to pins, so a mere click (well, a long click, a drag, okay?..) verifies connectivity.
10 grid on schematic is only practical if the symbol pins are aligned to it as well.
Shudder, off-grid pins... I've only seen it a few times, and only once not bothered to clean it up... now I feel dirty...
