Author Topic: How do I highlight a net in the PCB editor?  (Read 3872 times)
Offline hkBattousaiTopic starter
« on: September 28, 2014, 10:47:50 pm »
I'm trying to find all tracks which belong to a certain net. I googled it and found how to do it in the schematic editor here.
I want to do the same thing in the PCB editor. How do I do it?
« Last Edit: September 28, 2014, 11:01:26 pm by hkBattousai »
Offline free_electron
    • SiliconValleyGarage
Re: How do I highlight a net in the PCB editor?
« Reply #1 on: September 28, 2014, 11:11:50 pm »
s-n select net
« Reply #2 on: September 28, 2014, 11:31:36 pm »
Thank you. That works.
But there is one more thing. I need to find the location of a net before highlighting it. For instance, I'm trying to find and highlight a net named 'HB1_1'. How do I locate it in the PCB document?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: September 29, 2014, 12:23:46 am »
Lots of things:
- CTRL+click on the net (assuming you are already looking at part of it!)
- There may be a dropbox on the menu bar (exactly what you're looking for!).
- I think the Design/Nets menu or dialog has some highlight features.
- PCB panel, dropbox I think
- PCB List panel, select nets / objects in net
- PCB Filter panel, Net = '<net name>' (can also filter... well, any damn thing you can think of)
- Place a bit of track, edit it to assign net manually, then CTRL+click to mask the rest, or P, T (begin routing) and click on the trace (same as CTRL+click but shows the ratsnest to the rest)
- etc...
Seven Transistor Labs, LLC
« Reply #4 on: September 29, 2014, 03:12:49 am »
s-n click in blank space. popup comes. select net from list .
