Electronics => PCB/EDA/CAD => Altium Designer => Topic started by: Amazing on June 25, 2017, 09:54:25 pm
Do any of you know how to turn off the highlighting that shows which xsignals trace you are looking at?
Once I've clicked on an xsignal, the only way I can find to get rid of the highlight is to close the file.
I'm still on 16.
Thanks!
I think clear filter will work ( shift + C ) otherwise go to x signals list from the drop down and try highlighting some other signal.
Clear filter doesn't clear it. Highlighting some other signal works but then I've just got that
signal highlighted.
Go back to the PCB Panel and Select Nets (Not xSignals) then select clear.
I agree with you, clear should un-highlight the selected xSignals
Thanks! That did the trick.
Ha ha :-DD that's what I said too in the second option ...
