Author Topic: How to open paste mask for a PTH  (Read 3211 times)
Offline halexaTopic starter
« on: August 27, 2018, 05:40:38 am »
I have a pin in paste connector that will be part of the reflow assembly. So i want to open the paste mask over the PTH on the connector but i cant get Altium to do this for me  |O.  Anyone knows how to do this....
« Last Edit: August 27, 2018, 06:15:58 am by halexa »
Re: How to open paste mask for a PTH
« Reply #1 on: August 27, 2018, 06:18:12 am »
Update:
I solved it temporary with drawing an arc over the holes on the paste layer, but I would prefer to have this feature as automatic rule/setting to avoid bulk copy paste errors when you have multi pin connectors.
Offline mengfei
  • Country: ph
« Reply #2 on: August 27, 2018, 09:46:39 am »
in AD18 you have the option to change the size, in older versions just double click on the pad & check it's properties
« Reply #3 on: August 27, 2018, 10:27:07 am »
Seems like Altium wont create a paste mask expansion for PTH. And there is no option to choose if it shall be on top or bottom layer.
Offline ajb
« Reply #4 on: August 28, 2018, 12:32:29 am »
It may be better to draw the paste mask manually in the footprint.  Also, I don't think you want to have the paste mask open over the through-hole anyway, do you?  I expect that would lead to poorly-controlled solder quantity (both because some will get squished down into the hole, and the paste in/over the hole will tend to get pushed out when the pin is inserted).
« Reply #5 on: August 28, 2018, 05:15:43 am »
Yes I do, the connectors are "Pin in paste " or also known as "Through-hole reflow" (THR).
https://www.phoenixcontact.com/online/portal/us?1dmy&urile=wcm%3apath%3a/usen/web/main/products/technology_pages/subcategory_pages/PCB_mounting_THR_soldering/49161e67-818f-4a9c-b0cf-c91ba80b2b42
