Author Topic: how to reduce ground symbol size?  (Read 1536 times)
Offline DaxxinTopic starter
« on: April 02, 2018, 07:48:56 pm »
actually working with very dense schematic and power symbols too big.
Offline ajb
Re: how to reduce ground symbol size?
« Reply #1 on: April 02, 2018, 08:33:39 pm »
AFAIK You can't.  FWIW, I usually use the bar symbol for ground, and the arrows for voltage rails as these are the most compact.
But if your schematics are so dense that the default symbols are that problematic, then it's probably too dense to be legible, in which case you should go up a sheet size or break the sheet down into more than one subsheet.
The following users thanked this post: Araho, julianhigginson
