Author Topic: How to select multiple pads easily  (Read 648 times)
Offline ali_asadzadeh
  • Country: ir
    • ASiD Designer
« on: December 10, 2018, 02:08:35 am »
I want to select some pads like dragging a rectangle to select them and use Interactively route multiple connections, But It seems the selection box does not allow me, and I should select all the pins one by one, do we have something in aid?
You can order parts from www.ASiDesigner.com
we are a wire-based company
Offline T3sl4co1l
    • Seven Transistor Labs
Re: How to select multiple pads easily
« Reply #1 on: December 10, 2018, 04:34:09 am »
If you want to avoid the popup box thingy, lock the component (right-click on it, or set its property any other way).
Unfortunately the built-in select won't do non-free pads.  You could query it, maybe even write a script to make a mouse-driven InRegion query command that's more powerful than select, but yeah, more effort to figure it out. :-//
Seven Transistor Labs, LLC
Bringing a project to life? We can help.
Offline Deridex
  • IMHO
« Reply #2 on: December 10, 2018, 05:37:06 pm »
Try to keep the Ctrl-Key pressed while dragging the rectangle.  ;)
  • Country: ir
    • ASiD Designer
« Reply #3 on: December 10, 2018, 10:54:21 pm »
Thanks ;) ;) ;)
Offline mengfei
  • Country: ph
« Reply #4 on: December 18, 2018, 05:21:42 pm »
Edit > Select > Toggle Selection
now you can click on each pad w/o shift/crtl key
The following users thanked this post: ali_asadzadeh
