I assume you're talking about printing a PCB document?
rather than doing a "pcbprint" from the outjob, these days you'd be better off setting up the drawing in draftsman, and then printing the draftsman document from your outjob.
Draftsman is actually very useful, and I found it had a pretty minimal learning curve once I decided to start using it.
