Thanks for all replys,
"is the SoM locked?", Falcon69, i'll try do with lock and unlock ... And the same thing happens
"1/ Do either of your library components contain a "keep out" area within their bounds? Many standard Altium library components do.
2/ You may have a design rule set - ie minimum spacing component-to-component say 10mil"
DerekG, the footprint of this component don't have any "keep-out", only Top Layers. Now, this component spacing configuration, I do not know. The settings I found, I did. Maybe there are some that are missing yet.
"If you disable online DRC (Preferences > PCB Editor > General, under "Editing Options") can you put the resistors where you want? If so, and you then run DRC, what errors does it give you for the resistors/SOM?"
ajb, I thought about it too, and I disabled the DRC, but that did not help.
