Author Topic: Named polygon direct connection and another clearance  (Read 371 times)
Offline Kanc1erz
  • Being a noob the whole life :)
« on: January 17, 2019, 10:02:05 pm »
is there fast possibility to make a named polygon using direct connection and another clearance? For instance:
I got converter MP3414 nad instead of routing it normally it would be better to make those connections (with inductor, caps and so on) using a polygon.
Now I am doing it by writing rule like: InComponent('U7') or InComponent('L1') etc. but it would be more convenient if I could write: InNamedPolygon('MP3414_Inductor'). It obviously doesn't work, as in the screen below.
Maybe you have some other "pro tips" for noobs like me? :)
Offline Kanc1erz
Re: Named polygon direct connection and another clearance
« Reply #1 on: January 18, 2019, 12:46:43 am »
The answer is: IsNamedPolygon('PolyName')  :-[  |O
« Last Edit: January 18, 2019, 01:22:16 am by Kanc1erz »
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: January 18, 2019, 08:33:18 am »
Polygons are weird... sometimes you use InPoly, sometimes you use IsNamedPolygon, sometimes you... ::)
Seven Transistor Labs, LLC
Bringing a project to life? We can help.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: January 21, 2019, 02:11:17 pm »
In access the objects that make up the polygon ( a polygon is a tlist of vectors)
Is means the object itself.
Offline Pseudobyte
« Reply #4 on: January 23, 2019, 03:41:49 am »
Another strange thing is that copper polygons are not considered electrical by the "IsElectrical" query. That one had me scratching heads for quite awhile.
A guy just wanted to write a board outline rule for copper and my polygons were not following the rule. If it wasn't for the whole test query feature I would have gone insane long ago.
“They Don’t Think It Be Like It Is, But It Do”
