I just pretty much started using Altium, I really like it so far compared to Eagle, though it certainly has some things to get used to!
One of my first questions is in 3D mode t renders all of these wierd circles and mil measurements on the copper, how can this be turned off/on?
Is it possible to output a high quality render of the 3D board to an image?
Also I have a library component I made for the LM2596 which has a fill and vias for the tab of the 263 package to connect to, however there is no way I can find in the PCB Library editor to tell it the via's and fill are GND net (If I go to properties to the Net setting there is no listings to choose), which results in all those via's refusing to connect to my poly fill ground plane on the bottom layer.
Thanks in advance for the help!
