Author Topic: Pads .pcb file into Altium  (Read 1921 times)
Offline sparqq
« on: November 02, 2017, 08:50:41 pm »
I've been lurking a while and of course watching the Dave his YT channel but now need some help with a little problem.
I have a Pads design in a .pcb format which is not able to be imported to Altium with the wizard. Altium only supports the Pads ASCII format, but I don't have Pads to save the file it in ASCII. Anyone has suggestion on how to do this import?
Offline DerekG
  • Country: nf
Re: Pads .pcb file into Altium
« Reply #1 on: November 02, 2017, 09:32:15 pm »
If you are willing to send the file to someone with PADS, perhaps they will kindly convert it to PADS ASCII format for you.
There are lots of import & export filters in DipTrace .......... but I too can only import PADS ASCII files.
I also sat between Elvis & Bigfoot on the UFO.
Offline sparqq
« Reply #2 on: November 02, 2017, 10:59:16 pm »
I've no problem with sending the file over, it's not rocket science. Just need to be saved in ASCII format.
Offline GreggD
« Reply #3 on: November 02, 2017, 11:01:18 pm »
If it is Pads 9.5 or older I can do it. If it is small attach it in a post here as a zip. If big upload it to tinyupload dot c o m and post the link here.
Offline DerekG
  • Country: nf
« Reply #4 on: November 02, 2017, 11:30:12 pm »
Better that the two of you communicate via EEVBlog personal message rather than put the file up for everyone to see.
You can swap email addresses / links via personal message.
Just let us know if you have success.
Offline sparqq
« Reply #5 on: November 08, 2017, 12:36:51 pm »
I've send you a DM with my e-mail but no answer so far.
Any one else who can do the conversion for me?
Offline Agrum
« Reply #6 on: November 09, 2018, 01:32:47 am »
Hello,
I have exactly the same problem described in this topic.
I have a .pcb file, I can open it with PADS free pcb viewer but I want to open it in Altium. I think that the only way is to covert it in ASCII but I don't have PADS :(
Can someone help me? These files are not private, I can share them.
Thanks
Offline Giaime
« Reply #7 on: November 09, 2018, 10:06:37 pm »
Hello,
Thanks
You can send them to me, I have PADS Vx.0. Write me a PM.
The following users thanked this post: Agrum
Offline Agrum
« Reply #8 on: November 12, 2018, 08:12:20 pm »
Hello,
thank you so much, I have sent you a pm
