Author Topic: Planar inductor in PCB  (Read 7012 times)
Offline ali_asadzadehTopic starter
« on: September 24, 2018, 06:17:46 am »
I want to keep the inductor Trace width and spacing to a fixed value, I do not know how to do it in altium, since all the tracks have the same net, do you have any Idea how to implement it?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline mrpackethead
  • D Size Cell
Re: Planar inductor in PCB
« Reply #1 on: September 24, 2018, 06:35:01 am »
Build it as a component, then bring it in as a part.  Albeit a part that is ony made up of copper on the board.
Online ajb
« Reply #2 on: September 24, 2018, 06:40:59 am »
Set up a grid where the spacing is equal to your terrace width + space to make drawing the coil easier.  Use a net tie to prevent shorts between the ends of the coil.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: September 24, 2018, 06:50:44 am »
Yes, make a footprint and assign it the Net Tie property.
Seven Transistor Labs, LLC
« Reply #4 on: September 24, 2018, 08:12:40 am »
The problem still remains, how to make a footprint! precisely :( making sure the trace and spacing remains the same.
Online ajb
« Reply #5 on: September 24, 2018, 03:01:43 pm »
For a square coil as you've shown, just set up the grid so that snapping to it will give you the correct center-center spacing of your turns.  Setting the trace width should be obvious.
For more challenging shapes you can use a more sophisticated drawing program to create the shape and then import this as a DWG.  You will probably still need to do some massaging.
« Reply #6 on: September 25, 2018, 06:10:02 am »
Thanks for the tip ;)
Offline mengfei
  • Country: ph
« Reply #7 on: October 08, 2018, 06:29:13 am »
I remember in the Old Altium someone make a plugin for that but it was spiral
« Reply #8 on: October 08, 2018, 01:27:39 pm »
Thanks, do you have the name of that plugin, or can you share it? :)
Offline mengfei
  • Country: ph
« Reply #9 on: October 09, 2018, 03:50:42 am »
will try to look for it somewhere in my drive
in the meantime try these
https://electronics.stackexchange.com/questions/231746/making-planar-transformers-in-altium/231756
Offline Gribo
I am available for freelance work.
« Reply #11 on: October 09, 2018, 12:39:46 pm »
Thanks :) :) :) :)
