Hi everyone,
I have a board with components on the top layer and electrodes on the bottom. On the bottom there are 20 electrodes and one polygone plan which is intricated between all the electrodes to fill the board.
See in attachment the two first images.
So in my project everything looks good.
I generated gerber files (Files->FabricationOutput->GerberFiles) I choose all the layer (to be sure everything is in it) and I generate the .CAM first (see cam.png in attachment)
In the Cam, my bottom layer looks okay, I can see my polygone plane.
But after that when I do Export->Gerber , If I look at the .gbl (which is the gerber bottom layer), It seems that the polygon plan is not there (see gerber.png in attachment)
Did you have the same issue?
Thank you very much
