Hi all,
For some reason, in one project, Altium layout view is not showing my polygons as filled - just the outline vertices, including an outline around another signal. It is as though they have been set to "inverse view," but I did not do that intentionally, and cannot find a way to reverse this. The polygons DO still show up when I generate a Gerber, so they are both still in the design and still poured, just not filled somehow.
The issue is correlated with my use of the "Collaborate, Compare and Merge" tool to aid in a design review of some small changes. However, on a test project, I cannot get this particular behavior to replicate.
An image of what I am talking about is attached. I am using Altium 15.1. Does anyone know what setting/view I've inadvertently triggered?
Thanks in advance for your suggestions.
