Author Topic: Polygons overlap  (Read 534 times)
Offline Agrum
Polygons overlap
« on: December 13, 2018, 10:37:42 pm »
Hello, I have a big polygon connected to "net A" and I want to create another polygon inside the first one connected to "net B".
Both polygons are on the same layer so when I do the second polygon it's overlapped to the first. How can I separate the 2 polygon between them without redo the first?
I hope that the question is clear,
thanks
Online veryevil
Re: Polygons overlap
« Reply #1 on: December 13, 2018, 11:45:59 pm »
Go into the polygon manager and increase the priority of the polygon connected to B
The following users thanked this post: Agrum
Offline Agrum
« Reply #2 on: December 14, 2018, 12:47:19 am »
Thanks, it works!!
Offline Deridex
  • IMHO
« Reply #3 on: December 15, 2018, 08:52:48 pm »
You can also you Altiums automatic to generate the priorities. It works quite well and i tend to not do it manually.
