So, i needed a plate to plate connector and came up with something like this (4 headers considered by altium as the same component) .
So when i'm tring to select multiple items inside this component (for example 2 SMBs) it moves the connector. So my question is: can you set a specific selection border for new components
Some assumptions-
Just a thought, since your connector is actually four connectors, which you buy individually don't make it one connector.
Rather place the individual conns on the board and make a union of them. This way your bom will be correct and no one needs special knowledge (it's not one connector, it's 4!) to assemble the board.
Also if you need board to board connectors, check out samtec, they have some small footprint high pin count parts.
Other wise the previous post is spot on, you have on big part so lock it down in order to select parts under it. Btw you will need a drc rule to avoid parts under/inside your big connector.
Sent from my iPhone using Tapatalk
