Hi All,
I have a weird issue with the sheet number on a particular project. There are 6 schematic drawings in the project.
I have a Title block that uses the Sheet Parameter "SheetNumber". On half of the drawings, the SheetNumber is displayed correctly ie "1" or "5" or "6" etc.
On the other pages, the area with the title block where the sheetnumber is displayed shows "SheetNumber: 3". It actually writes the string "SheetNumber:" in addition to the actual number.
This is not just limited to my Title Block, it also happens on the built in A3 title block.
On the affected sheets, I have tried making the SheetNumber parameter a Boolean/number/string they all have the same result. I have tried different values ie "Z" and I end up with "SheetNumber: Z"
Ideas?
Thanks,
Neil.
