Author Topic: Test Points - Plated VS Unplated?  (Read 4986 times)
Offline danskuTopic starter
  • I make things
    • Personal Blog
« on: April 27, 2017, 12:45:36 pm »
Hey, I was doing a design check on one pcb, and I am getting errors saying Unplated multi-layer pad(s) detected
I would like to understand what is the difference and problem from Unplated multi-layer pad(s), and I am also using them as VIAS.
Am I doing it wrong, and if so, what is the best way?
Thanks,  \$\Omega\$
Offline ahbushnell
Re: Test Points - Plated VS Unplated?
« Reply #1 on: April 27, 2017, 12:53:50 pm »
Shouldn't a via have a non zero hole diameter?
  • I make things
    • Personal Blog
« Reply #2 on: April 27, 2017, 01:12:35 pm »
Yes, but I am using it was a Test Point (please don't shoot me  |O)
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: April 27, 2017, 02:17:01 pm »
why do you want an unplated pad as a testpoint. ? if there is no plating there is no electrical contact ....
unplated holes are for mounting purposes.
plated holes are for component pins ( pads ) or interconnection ( vias )
both pads and vias can be a testpoint. simply check the assembly or fabrication testpoint flags.
Offline Mikekoz13
« Reply #4 on: April 27, 2017, 02:58:16 pm »
The only reason I could see to have the hole(s) unplated is if you're putting some type of swaged in test point (terminal) in the holes. Other than that .... plated.
  • I make things
    • Personal Blog
« Reply #5 on: April 27, 2017, 03:18:12 pm »
Thank you guys,
Changed all my Test-Point library to platted  :-DD
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: April 27, 2017, 04:57:29 pm »
If you want test pads without holes, set the Pad object to Top Copper.  Then you get an SMT pad.
Seven Transistor Labs, LLC
