Author Topic: Component Pin INput from Excell.  (Read 529 times)
Offline mrpackethead
« on: January 20, 2019, 07:48:10 am »
I have a 670 pin BGA to create in Altium.  I have the pin descriptions in Excel,   i'm wondering is there any way to autoamaticlly import them.
Smart Paste only lets you copy onto parts that already exisit, so it seems i need to at a mimimum create all the pins, by hand.
Online T3sl4co1l
    • Seven Transistor Labs
Re: Component Pin INput from Excell.
« Reply #1 on: January 20, 2019, 10:07:41 am »
Use the SCH List Panel.
Seven Transistor Labs, LLC
The following users thanked this post: mrpackethead
« Reply #2 on: January 20, 2019, 01:38:46 pm »
Tim, that only allows you to edit/paste data into pins that already exisit.
I found that you can do this by usign the compoent wizard, and you can paste in new pin data.
Online T3sl4co1l
« Reply #3 on: January 20, 2019, 04:13:05 pm »
Meh, copy and paste pins until you have enough of them.  Then set in List. :)
Or paste array (if it's in SCHLIB Editor? I forget).
You'll probably want to scratch everything together on one symbol/sheet, then copy parts out to separate IO banks or however you like dividing up those beasts.
« Last Edit: January 20, 2019, 04:18:13 pm by T3sl4co1l »
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: January 21, 2019, 02:06:26 pm »
in schlib editor : use the schematic part wizard. you can copy paste the table in there directly.
