Nah, I use Altium primarily.
I've used PADS before, if that's moderately related, but it's pretty crap at drawing, I suspect mainly because its pours are constructed from myriad traces, and it doesn't have a shortcut to draw (let alone construct) a proper fill as such. Also, being old and probably not using acceleration (e.g. DirectDraw), or even up-to-date GDI objects (which might be expected to be better optimized).
Altium's drawing speed is highly adapter dependent. The machine I use at work has dual (Intel and Nvidia) graphics inside, selectable by program; Altium is sketchy until you switch it over, then it's quick as anything. My desktop (with a GTX550Ti) hardly notices a thing. I've seen it work well on Intel graphics sometimes, and poorly for other things too. Sadly, it's one thing that's really not made for anything else... but if you're going to the trouble of buying Altium, you can surely afford a $100 graphics card, so it shouldn't be a big deal.
