I am learning about BJT transistor and I understand them quite well know... I guessed
until I saw the following simple circuit:
http://www.reconnsworld.com/audio_simplepreamp.htmlWhat I do not understand: passed the first AC coupling capacitor, the voltage can be
negative. Usually, the transistor is base voltage biased in such a way there is an offset
so that negative voltages are not an issue. But in this schema, there is no offset. I built
it, and it works: I get some Vbe < 0 and get a correct Vc with no clipping...
How is it possible, can someone explain to me what I am missing? I guess there is
something with a current involved from Vcc to C1 as the voltage accross C1 becomes
< 0, and that it acts as the Vbe offset I do not see... but not clear at all to me.
Thanks!
Best regards,
texane.
