Author Topic: [ comparator with npn transistors ]  (Read 9272 times)
Offline texaneTopic starter
« on: January 17, 2010, 08:36:50 am »
I am working on a small project for
which I need to compare a voltage
to 2.5v. The compared voltage is
called Vin. If Vin is more than 2.5,
I need a Vout to 5V, otherwise to 0V.
I do not want to use a comparator,
but transistors for learning purposes.
I was thinking about using the a
voltage divider so that Vin is scaled
from [0, 5 volts] to [0, 1.4] thus my
comparing voltage become 0.7v (ie.
was 2.5v in [0,5] becomes 0.7v in
[0,1.4]) which I plug to an opamp
which is linked to the transistor Base
pin.
< 0.7v wont switch the transistor ON,
otherwise it will. I can replace the opamp
with another transistor.
Is the basic idea good? Any comment
welcome! I have read relying on the
BaseEmitter voltage drop is not a good
thing...
Thanks for helping,
Andrew
  • Guest
Re: [ comparator with npn transistors ]
« Reply #1 on: January 17, 2010, 12:12:49 pm »
You want to use an OpAmp, but not a comperator?
I'll tell you a secret. A comperator is an OpAmp, just specially optimised for working as a comperator. So I don't see the learning experience here - replacing a comperator (which is an OpAmp) with an OpAmp, albeit one not specially suited for comparing.
« Reply #2 on: January 17, 2010, 02:32:43 pm »
hi,
forget about the opamp, and replace it
with a transistor providing the same
voltage (ie. Ve = Vb - 0.6) but with a
gain in current. My question was about
relying upon the drop of 0.6v (0.7v) at
Vbe.
Thanks,
f.
Online Zero999
  • 0999
« Reply #3 on: January 17, 2010, 05:53:11 pm »
You'll need several transistors, not just one.
Google for 'differential pair' and learn the basics of differential amplifiers which is what goes into op-amps and comparators.
Look at the datasheet for a comparator and op-amp IC and base your design on it.
Accept, that your circuit will never be as good as an IC because none of the transistors are matched.
« Last Edit: January 17, 2010, 06:44:42 pm by Hero999 »
« Reply #4 on: January 17, 2010, 06:03:59 pm »
ok, thanks for pointing me to the right direction.
Thanks,
