I am working on a project where I load capa then discharge them rapidly
in a coil using a MOSFET to produce a high magnetic field. To be efficient, one
constraint is to make the field as short (in time) as possible. Thus, di/dt is
very high, and the back EMF can reach up to 20kV... and I did not find any
'flyback' diode that can handle such a voltage. I found some monster diodes
that can handle 6kV, but they burned up during the first test ... :/
I try to change the switching MOSFET by an IBGT, but same problem as
above.
Maybe there are some well known techniques to address this issue, and your
help would be very appreciated
Cheers,
Fabien.
