I need to switch on off a 5v source using 3.3v command (ARM MCU GPIOs).
The load can draw up to 2A, typically 500mA. In this application, frequency and
rising times can be omit (the source is switched on or off by a human).
One constraint is that the analog switch must be in serie between the source
and the load (high side design).
I planed to use a P channel MOSFET, but looking at various datasheets show
typical Vgs threshold voltages in [2 - 4]v. 2v is too close, as 5v - 3.3v = 1.7v, and
I am looking for a Vgs threshold more in the [3.5 - 4]v range, or some dedicated
IC that specifically fits this purpose ... Have you any reference?
Currently, what I do is to use a N channel MOSFET to convert the [0 - 3.3v] to
[5v - 0v] and use it to control the second P channel MOSFET. But it makes 2
FETs.
Thanks for your help!
