As an exercise, you can demonstrate the formula of the first example : Vout = (1+ R1/R2) Vref. You will see that it does not depends
on R3 nor on Vin.
If you want to get benefit from this simple example, you will have to determine also the minimum and max values for Vin, and as said by Andy, the required specifications of the resistors.
