Hi everyone,
I've been trying my hand at making a NiMH charger (I'll explain my project below).
I know the topic has been extensively discussed to hell and back, however surprisingly there are
very few open source circuits available online.
My requirements are that it needs to be capable of charging two AAA cells @900mAh each (wired in series), to run off USB +5V, and to be reasonably fast (3, 3.5 hours is acceptable).
I found
this one charger circuit and I think it will be suitable for my purposes, however there are a few things in it that I can't wrap my mind around. I tried asking the author however I don't think he's active on that blog anymore.
https://arduinoelectronics.wordpress.com/2012/04/20/smart-nimh-battery-power-charger-based-on-attiny85 So, if you've taken a look already, you would have seen the Red LED that's used to provide constant current. I'd venture to say that it is a neat trick (even if I disagree with it).
Here come my questions:
1) Can anyone explain to me how that Red LED constant current thing works? I understand as far as forward voltage drop, but not the part about the constant current, not really. I've remade the schematic in a SPICE simulation environment and that LED never blinks for me, which is clearly different from the author's video. I get pulsed current, but not the blink.
2) There is a Schottky below the PNP. Is there any other function to it other than to protect the components behind it from the battery connection?
3) Can the circuit work as-is with +5V, instead of the +12V specified in the schematic? The author says it was designed for 6 cells @2500mAh, however I think it can work as-is for my requirements as well: 2xAAA cells @1800mAh. I only got rid of the linear v.regulator part of the circuit, everything before the Red LED, and replaced the 12V source with 5V. I'd appreciate if anyone can make the corrections (if any), or better yet teach me about what needs to be corrected.
Finally, if anyone can link me a better circuit, I'll gladly take it. Any advice is welcome at this point, I've rarely done anything to do with NiMH/NiCd charging before, other than some research in the past few days.
My application is as follows: I need a small circuit to implement within the enclosure of a joystick controller that has two built-in AAA batteries. Ideally I would have wanted to replace those with LiPos and have a single-chip charging setup, but the problem is I can't bloody fit any decent capacity LiPOs in the casing, I'm very limited in terms of space. The current draw of the joystick is about 15mA, which is quite a lot for e.g. those small 250-300mAh LiPOs. It would be discharged in a matter of hours...
So, I'm stuck with NiMH AAAs, and need an intelligent charging solution for the specific situation.
I'm not afraid of AVR, I've got a few different types at my disposal.
Thank you all in advance for anything you can throw at me.
