Hi everyone,
I bought a dash cam a while back and am not complete sure what is wrong with it. I'm thinking the internal battery is out of most of it's power or something. It works when I turn on the car and the time and date are always right when I start up the car. However, it use to turn off after a couple of seconds and properly power down so my last file would not be corrupt. Now after I shut off the car it pretty much just shuts down immediately and the last file is always corrupt.
To solve this, I was thinking of creating a dashcam ups connected to my car 5v -> dashcam ups -> dash camera
So the dashcam ups bypass will just feed 5v to the dash camera and when the dashcam ups notices that it is not being powered it will count 2 minutes and then turn off. This will let the dash camera finish it's 3 minute write cycle and the last file will be saved.
Now I'm not too sure how to make this... I know I will need
- some kind of timer (I thought it would just be easier if I use a digispark or arduino)
- A way to sense voltage coming from car usb port to tell when there is no more power
- A way to switch to battery mode if power is cut off from the car
- A 3.7v battery as a power source for the 2 minutes.
- A charging circuit for the 3.7v battery. I'm hoping for it to charge the dashcam ups's battery as well as passthrough the 5v to the dash camera at the same time.
Any help would be appreciated. This dash camera has sadly(because I had accidents)/luckily saved me from he said she said arguments from a couple of accidents.
Thanks
