I watched Dave's review of the cheap, cheerful DPS3003 style buck power supplies. He sold me on them, until I actually speced one out to buy.
My use cases are basic electronics beginners stuff and Raspberry PI stuff were USB 3.3V/5V would be fine, but I also have ambitions for battery charger style circuits that would require 15V and the ability to test a 3A or 4A constant/limited current regulation circuit. So a 30V, 5A PSU sounded ideal.
Buying for a UK seller the DP3003 30V 5A version are about £30. Great. However, the still require a DC power source. That's where it all falls apart. I simply cannot find a domestic wall-wart that will produce 30V and 5A. The best I can find is a laptop PSU that delivers 24V and 4A and it costs £35.
Now on Farnell I can buy a professional single channel 30V 5A bench supply from Tenma for about £70. I can get a two channel PSU for £110.
The only use case I can see for this cheap buck converter PSU is to run one or more of them in parallel off the bench supply. So I could power two or more of the cheap PSUs from the expensive one, rather than buying the more expensive 2 or 3 channel bench supply. Does that even work, considering impedance and what not?
Thanks,
Paul
