Quote from: Cliff Matthews on January 23, 2018, 11:07:54 pmQuote from: kiwizz on January 23, 2018, 10:46:54 pmThanks for the reply - I don't see what you are referring to? previous schematic? forgot to add a link? Cheers!Ohh, yes, i'm sorry, forgot it hahahah....I'm not that up to speed in being able to read circuit diagrams like this - is it a variable power supply with current limiting? If it is, I'd like to have the PCB printed at some place like this https://jlcpcb.com/ and then put it together.Cheers!
Quote from: zvonex66x on January 23, 2018, 11:36:51 pmQuote from: Cliff Matthews on January 23, 2018, 11:07:54 pmQuote from: kiwizz on January 23, 2018, 10:46:54 pmThanks for the reply - I don't see what you are referring to? previous schematic? forgot to add a link? Cheers!Ohh, yes, i'm sorry, forgot it hahahah....I'm not that up to speed in being able to read circuit diagrams like this - is it a variable power supply with current limiting? If it is, I'd like to have the PCB printed at some place like this https://jlcpcb.com/ and then put it together.Cheers!It's very simple circuit, and yes this is voltage and current limiting. Becouse it had few components, you can do PCB by yourself at home..
Quote from: kiwizz on January 24, 2018, 09:31:41 pmQuote from: zvonex66x on January 23, 2018, 11:36:51 pmQuote from: Cliff Matthews on January 23, 2018, 11:07:54 pmQuote from: kiwizz on January 23, 2018, 10:46:54 pmThanks for the reply - I don't see what you are referring to? previous schematic? forgot to add a link? Cheers!Ohh, yes, i'm sorry, forgot it hahahah....I'm not that up to speed in being able to read circuit diagrams like this - is it a variable power supply with current limiting? If it is, I'd like to have the PCB printed at some place like this https://jlcpcb.com/ and then put it together.Cheers!It's very simple circuit, and yes this is voltage and current limiting. Becouse it had few components, you can do PCB by yourself at home..Is there a parts list, or can I just google for all the numbers on the diagram? Cheers.
@Simon, Why are the last 3 posts empty quoting without saying anything? Perhaps from the same IP?If the last two posters seriously want to gain a bad rap, you're getting successful at it
And I have made this one... it's more complex and it's not cheap, but it's pcb and you only need to buy all of components and solder it... when all is done, you should go up to 100$ so it's not cheap, but is good PSU.. take a look...https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F192415947108
Quote from: Cliff Matthews on January 28, 2018, 05:35:05 am@Simon, Why are the last 3 posts empty quoting without saying anything? Perhaps from the same IP?If the last two posters seriously want to gain a bad rap, you're getting successful at it zvonex66x screwed up while quoting several posts ago, leaving an unclosed quote tag, and that ripples through every time it’s quoted.
Quote from: tooki on January 29, 2018, 06:59:53 pmQuote from: Cliff Matthews on January 28, 2018, 05:35:05 am@Simon, Why are the last 3 posts empty quoting without saying anything? Perhaps from the same IP?If the last two posters seriously want to gain a bad rap, you're getting successful at it zvonex66x screwed up while quoting several posts ago, leaving an unclosed quote tag, and that ripples through every time it’s quoted.Then is better to not ppst anything here, becouse if you want to help someone like i did try it here, "discuss the merits"...
Quote from: zvonex66x on January 28, 2018, 09:19:02 am And I have made this one... it's more complex and it's not cheap, but it's pcb and you only need to buy all of components and solder it... when all is done, you should go up to 100$ so it's not cheap, but is good PSU.. take a look...https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F192415947108If you don't link to, or post the schematic, one could think you are selling these.. please, open a new thread to discuss the merits perhaps.. (the current thread is getting stale)).
