give it a test with the ol' DMM
With just it expected to be around 1ohm, testing in-circuit is likely not meaningful. This one looks like an 0603 or smaller on a still-in-used motherboard. It is easy to loose something that small when removed. I have yet to find a 0805 green LED that I knew for sure felt off the table and by now probably in LED heaven.
These days, I scotch-tape SMDs down on the table top and only remove it from the scotch-tape covering when I am fully ready to solder that specific SMD.
Leading zeros are not significant.
Trailing zeros are significant.
This is a good thought.
* 01R is 1ohm with 1-digit accuracy.
* 1R0 is 1.0 ohm with 2-digit accuracy.
Unless/until another reason pops up, I will take it as 1 or 2 digit accuracy, I suppose. But I am still uncomfortable with that since accuracy is typically specified as 1% 5%... This is too esoteric even for my curiosity.
