74HC574 will let you store 8 bits for as long as you like. You can create an equivalent circuit from NAND gates, but you won't save any space on the board.
TI "Little Logic" SOT-23 size D flip-flop
You may use a thyristor made from two transistors.
Quote from: rgawron on November 20, 2015, 10:56:39 amYou may use a thyristor made from two transistors.Or use a thyristor made from one thyristor ; )
But how do you make the first thyristor?
You can use a dual coil latching relay. It will remember the bit even without power.http://www.ebay.com/itm/10x-Panasonic-TQ2-L2-5V-Two-Coil-Latching-Signal-Relay-DPDT-5V-/321905891998?hash=item4af3161a9e:g:S1EAAOSwwbdWMdaT
Quote from: zapta on November 20, 2015, 01:34:05 pmBut how do you make the first thyristor?Out of a thyristor, obviously.
