Author Topic: 100M Resistor 4th B. white.  (Read 1263 times)
Offline VtileTopic starter
  • Ingineer
« on: January 22, 2017, 12:35:57 pm »
I have this 100Megaohm resistor, deep purple to brownish body. It is 100 megs since it divides 10V to 5V series with my 100Meg Multitester and so says also the colorcode: brown-black-purple-white
Now what is the White??? I have no source/reference that it even should exist in that place as a 4th band.  I'm just curious.. Anyone have any information what is this presumaply nonstandard marking.
I have no idea of the age of this as it is salvaged part from random electronics in the past (late 90s when it did end to my box of resistors).
« Last Edit: January 22, 2017, 02:23:13 pm by Vtile »
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: 100M Resistor 4th B. white.
« Reply #1 on: January 22, 2017, 03:03:54 pm »
For very high values, which will often be used at high voltages, you don't want a metallic ink like gold or silver, so white is probably used as non-shiny silver.
These VR68 high-voltage resistors use yellow instead of gold
From the datasheet http://www.vishay.com/docs/28907/vr25vr37vr68.pdf
Yellow and gray are used instead of gold and silver because metal  particles  in  the  lacquer  could  affect  high-voltage properties.
Day Job: Mostly LEDs
  • Ingineer
« Reply #2 on: January 22, 2017, 03:19:06 pm »
Oh, really nice. Thx.
It might indeed be the explanation, since it does have good technical reasoning.
The resistor I have also do have this hard enamel shine on it so it might indeed be a highvoltage range. Something over the typical jellybean dip to paint range anyway.
« Last Edit: January 22, 2017, 03:21:43 pm by Vtile »
