Author Topic: 10k Potentiometer fast question  (Read 3279 times)
Offline DellyjoeTopic starter
« on: June 25, 2013, 05:36:35 pm »
hello everyone im just about done my project i have two things to wire up and i don't know which two are the cold and which one is the hot.
i know for photometers you have two cold and one hot.
here is the data sheet that i found but it doesn't tell me anything.
http://octopart.com/datasheet/evu-e2af25d14-panasonic+-+ecg-573536-13329483
i have # 3
« Last Edit: June 25, 2013, 05:39:35 pm by Dellyjoe »
Joe
Offline Galaxyrise
Re: 10k Potentiometer fast question
« Reply #1 on: June 25, 2013, 05:53:44 pm »
resistors like that do not have a polarity
I am but an egg
« Reply #2 on: June 25, 2013, 05:56:01 pm »
wow i feel silly
thanks for the info
Joe
Offline Mr Smiley
« Reply #3 on: June 25, 2013, 06:04:46 pm »
Centre pin will be the wiper  :-+
If you want increasing Vout (centre pin) moving in a clockwise direction, looking from the front, Vlow goes to the left pin, Vout ( with respect to the left pin, Vlow ) comes from the middle pin and Vhigh goes to the right pin
If you want decreasing Vout (centre pin) moving in a clockwise direction, looking from the front, Vhigh goes to the left pin, Vout ( with respect to the left pin. Vhigh ) comes from the middle pin and Vlow goes to the right pin
There is enough on this planet to sustain mans needs. There will never be enough on this planet to sustain mans greed.
« Reply #4 on: June 26, 2013, 01:33:02 pm »
Thank you Mr smiley i found that out by playing around with it, but thanks again for letting me know if i didn't do that :)
Joe
Online Psi
« Reply #5 on: June 26, 2013, 11:07:11 pm »
