1. Adxl375 specifically mentioned about using 10uf tantalum capacitor on Vs.
2. What the reason for that?
3. What if I use 10uf ceramic for that.
I have read on internet thet ceramic has below drawbacks:
1. Aging
2. Voltage coeff
3. Piezeo noise
4. Flex crack (most severe)
After reading I guess since adxl375 is used for measuring accelration so most dominating reason to use 10uF tantalum will be piezo noise. Is it right?
But along with 10uF tantalum, datasheet specify to use 0.1uF ceramic also, which may go opposite to my above reason.
I want to know what exactly the reason for using tantalum here.
