Author Topic: 10watts for all 4, will it work  (Read 13613 times)
Offline dave_j_fanTopic starter
  • Country: in
« on: November 05, 2017, 10:41:53 am »
 As making basic EI transformer inverter is super easy  i am planning a thing
  i am adding a triac based switcher to make sure the apparent LED load is within 10W in the inverter
  so a bulb is made on at a time and fast switch is done so that every bulb look steady glow but inveter can be used is very low watt
  Experts please suggest will it work  ?
clarification :::
It is not a DIMMER
it is NOT a XMAS light
I dont want to use 12V LED
just DIY $5inverter should be able to do double duty that is 10W inverter drives 20W
« Last Edit: November 08, 2017, 09:36:23 am by dave_j_fan »
Online Zero999
  • 0999
Re: 10watts for all 4, will it work
« Reply #1 on: November 05, 2017, 10:54:13 am »
This seems like a bad idea.
Why not simply use 12V LEDs?
The AC is only converted back to DC inside the LEDs anyway, so it makes sense to use LEDs rated to the correct voltage in the first place.
Online Twoflower
« Reply #2 on: November 05, 2017, 11:03:29 am »
I'm not sure if I understand your plan correct: You try to sequentially power one bulb or probably two  at the time, switch to the next and so on. Is my assumption correct?
In that case you'll probably run into problems. As the high voltage (110V/230V) LED bulbs contain some circuit that could behave funny if it receive the supply in bursts. It could even shorten the lifetime as the primary capacitor in there will be under additional stress. But again this depends on the circuit in the bulbs. Cheaper ones might survive that better but probably flicker a lot (the ones with no build-in switching circuit).
As alternative: Have you thought to skip the inverter and use 12V DC LED bulbs? They might behave better if driven from a PWM source. Or better use LED bulbs that don't need to be dimmed down at all. As side effect: This will have a higher efficiency as you don't to the surplus converting to the high voltage and back down (within the LED bulbs).
  • Country: in
« Reply #3 on: November 05, 2017, 11:29:55 am »
i am making a box inverter and user can use any LED bulb . not a emergency light .. wire length they can use higher
that makes it more suitable also 12v DC bulb is vv rare
  • Country: in
« Reply #4 on: November 05, 2017, 11:35:30 am »
12v bulbs not a option longer cables will be used to put ,say 2 story building .
I have used  220V LED bulbs for very longtime on  almost square wave inverters bulbs dont care  of that .
Keeping inverter cost low is main needed , efficiency is not that of concern as similar inverter running with loong 12hr backup( not having Triac switcher)
Online wraper
  • Country: lv
« Reply #5 on: November 05, 2017, 12:35:25 pm »
You certainly cannot do this. And if you use normal quality LED bulbs which include driver circuit, you won't even decrease power consumption. They will just charge internal capacitor with much higher current in the moment power is applied. Thus reducing it's lifespan. If you need to decrease power consumption, use lower power LED bulbs.
The following users thanked this post: dave_j_fan, orolo
Offline orolo
« Reply #6 on: November 05, 2017, 12:51:29 pm »
Big Clive wonderfully explains the problem with triac dimming and LED lights in this video.
Online Zero999
  • 0999
« Reply #7 on: November 05, 2017, 03:59:20 pm »
I agree. Another issue is with using a square or modified sine wave, a capacitive ballast, used in many LEDs, the current will be much higher, than the design value, causing unreliability, possibly smoke and fire.
Offline jeroen79
« Reply #8 on: November 05, 2017, 04:56:53 pm »
I don't get what this TRIAC switcher is supposed to do.
Is it just a dimmer?
If you're starting with 12V DC then converting to AC seems inefficient to me.
Look for suitable 12V leds instead.
Online Zero999
  • 0999
« Reply #9 on: November 05, 2017, 05:52:29 pm »
Why not? At lower voltages, the current required for a certain amount of power, will need to be higher, but it's only 10W, which is under an Amp at 12V, so the cable doesn't need to be very thick. If the maximum voltage drop is 1V, at 1A, then maximum cable resistance is 1Ohm. 1mm2 cable has a resistance of 18.1mOhm/meter, so the cable can be as long as 1/0.0181 = 55.25m, or 27.6m as two wires will be used: one for the positive and anoter negative.
https://www.tlc-direct.co.uk/Book/5.3.6.htm
Online Twoflower
« Reply #10 on: November 05, 2017, 06:04:31 pm »
OK, Hero999 beat me with the post by a few minutes. But I'll post it anyway  ;D
The statement "about the higher drop because using 12V compared to 230V" doesn't really count for such low loads. Your schematics show a 10W inverter to 4 bulbs. That allows max. 2.5W per bulb. At 12V this is 210mA. Assuming a 50m (actually 2x50 as you have the return wire as well) wire with 1mm^2 has about 1.7Ohm. That means you loss at the wire is less than 74mW.
Of course if you want them to 'glow' dimly you can probably drive the LEDS with even lower power and the cable losses will go down a lot. At 1W the losses are already down to 12mW as the current appears squared (P = I^2 ยท R).
If all bulbs are 50m away that sums up to 300mW. Please tell me that your self build inverter has lower losses than 300mW or better than 97% efficiency. Which would be extremely well for a 12V to 230V inverter, you could make money with the design.
Edit: Changed calculations from 5 to 4 Bulbs..
« Last Edit: November 05, 2017, 07:48:46 pm by Twoflower »
  • Country: in
« Reply #11 on: November 07, 2017, 10:37:50 am »
it is not a design challenge ,,,
purpose is to deliver low cost inveter for small shop and students
12v dc wireloss make  unsuitable for little longer lenths of wire where two bulbs will light up ;
like a poor mans house
then u may ask  why not make 80watt inverter ?
this his cost bench mark and needs bulk battery
even if loss is low 12V leds are vry rare to find , and  during gridpower they need 12V SMPS to run adding to inverter  cost
(inverter auto switch)
« Last Edit: November 07, 2017, 10:50:36 am by dave_j_fan »
Online Zero999
  • 0999
« Reply #12 on: November 07, 2017, 02:04:43 pm »
What's the maximum wire length?
As we already stated, the loss in an inverter will exceed that of a 27.6m, 1mm2 cable, at 12V 1A, which is over 91% effient.
And as 12V LED bulbs are widely available. I suggest MR16 / GU5.3 lamps. I've recently purchased some for my parent's and sister's house. They've very efficient and run cool, compared to the halogen lamps they're designed to replace.
Another option is using a higher DC voltage, such as 24V or more, but I haven't looked into the availability of such LED lamps.
  • Country: in
« Reply #13 on: November 08, 2017, 06:00:41 am »
i request all to see the scenario that all bulbs are not available all parts of world. even 12v ones of substandard quality in many parts  :=\
if the 12v bulb topic is pulled again  i will have to walk off .  |O
if somone can highlight 230v switching plan that is running on off at very fast rate like 1Khz  please share
running 12v LED , i dont want to do , the reasons already stated ...... please reply on 230v led  only
Online Zero999
  • 0999
« Reply #14 on: November 08, 2017, 09:16:01 am »
Why not buy an off the shelf 230V inverter? It will be much cheaper than making one.
https://m.ebay.in/itm/3-LED-STRIP-SMD-WATERPROOF-LIGHT-MODULE-5050-WARM-WHITE-DC-12V-FOR-CAR-BIKE-/181612437698?hash=Ng==
The LEDs can then be switched using plain old mechanical relays.
EDIT:
Sorry missed this:
Why do you want to do that? Do you want to dim the LED? If so, that's not feasible with 230V 50Hz.
Why not use a dimmable LED? If so you'll most likely need a pure sine wave inverter.
Another option is several lower powered LEDs and a circuit to control how many are switched on.
« Last Edit: November 08, 2017, 09:19:42 am by Hero999 »
  • Country: in
« Reply #15 on: November 08, 2017, 09:29:04 am »
Hero999,
post 0 has all details . Why all are serving 12VLED  |O  |O  |O
for the the ones who dont read  post 0
- It is NOT a tip top light
-it is NOT dimmer
-YES its is SOMTHING else
" it is to switch load very fast so that 10W inverter driver 20watts LED "
 i hope no 12v LED suggestions will come
« Last Edit: November 08, 2017, 09:31:22 am by dave_j_fan »
  • Country: in
« Reply #16 on: November 08, 2017, 09:33:15 am »
my inverter is $5 inverter compact , "DIy"
and 10watts capacity
can it drive 4 of the 5watts LED
Online Zero999
  • 0999
« Reply #17 on: November 08, 2017, 10:00:18 am »
Hero999,
I posted the wrong link:
https://m.ebay.in/itm/150-Watt-Inverter-12V-to-220V-DC-to-AC-Converter-Board-For-Home-Car-Solar-DIY-/282609533548?hash=NA==
Don't be so childish! You don't make the rules here. People are free to suggest what they like. If you don't like it, you're free to ignore it.
-it is NOT dimmer
Bad idea. It wont work. If you can't get a larger inverter, you need lower power LEDs.
No, that would overload it, causing it to overheat or some protection circuit to kick in.
If you've made the inverter yourself, then why not post the schematic and a picture so we can suggest how to increase the power rating to 20W?
Online Twoflower
« Reply #18 on: November 08, 2017, 07:26:31 pm »
As many times said: Will it work? --> Probably not.
And as this was said we tried to provide you alternative solutions which in general, but not for every case, is superior to your solution. And as we don't know your specific problem we just provided a solution that works in general. If you're not happy with this, you should provide more input to work with. Or take the short answer to your question in the subject line: Probably not.
Switching the different lanes at high speed might have a negative impact at a) The losses on the cables and b) emit electro magetic noise.
As this was noted here: Your results might be unpredictable. As there are different ways to implement 230V LED bulbs. From 'put as many LEDs in series plus a small resistor' to a full blown SMPS. If the LED bulbs contain a SMPS which might not behave as you hope. The input capacitor will have a high inrush current which might exceed the rated 5W of a LED lamp in operating mode. If you switch off and on the supply the high inrush current will probably repeat. If you use the 'simple' ones they might start to flicker annoyingly.
And something you should consider while implementing your inverter: Be aware that some LED bulbs might require a frequency close to 50 or 60Hz. If the bulbs use a capacitor to reduce the line voltage that could fry the bulbs easily.
  • Country: in
« Reply #19 on: November 08, 2017, 09:59:59 pm »
I thought why not make the jig ...
 The bulb fry myth has been busted , i was able to reach a steady glow
 the SCR based sequencer works beautifully! ;D
 All 4 channels are active ... but SCR and bulb is on one channel
 i will add 3 more SCR and bulbs .
 testing with 4w PHILIPS bulb on 230V AC
 I have been using SMPS LED lamps , they seem to respond well to few Khz frequency
 all shops and places use squarelike inverters with higher switching freq. the bulbs are doing just fine.
 (may reduce 1year life, but thats ok  of the avg life is say 4 year , reducing to 3year is unnoticable)
 However , i have delivered all inverters to poor and needy. I will make one 10watter
and check if its driving well .
But i appreciate the know how shared so far
« Last Edit: November 08, 2017, 10:06:17 pm by dave_j_fan »
  • Country: in
« Reply #20 on: November 08, 2017, 10:12:38 pm »
Hero999,
 buying 150w inverter not an option ..most of these are china clones cant be sure of reliability .
 the higher watt inverters waste more watts if the load is 10-20w .
when Qn is : can i drive 20w load on 10w with sequencer
Answer cannot be make 20w inverter
i can make even 100watts one ... but cost and needed battery will make it unusable for the masses .
next is regrding posting my inverter scheme.. thats design trademark
its is $5pack with charger and inverter and autoon combo... with battery protection circuits
Online Zero999
  • 0999
« Reply #21 on: November 09, 2017, 09:43:40 am »
Yes, you need an LED with a switched mode power supply. There will be a limit to the maximum frequency of the supply voltage, because the bridge rectifier on the input stage will gradually become less efficient, as the frequency increases. Running on 200V to 300V DC is another possibility.
Hero999,
If you designed the inverter, then you should know whether it can power a 20W LED or not, so why are you asking that question here? There's no point in keeping the schematic for your inverter secret. There are 100s of schematics for inverters, which can be found on the Internet and many people here are capable of designing one from scratch.
Or is the question not about the inverter, but the sequencer? Can you post a schematic for that or is it a secret too?
Offline mikerj
« Reply #22 on: November 09, 2017, 11:05:04 am »
I am at a total loss to understand the point of this.  Rather than trying to dim a 10W lamp so it only consumes 2.5W, why not start with a 2.5W lamp?
How are you intending to switching a TRIAC on/off at a frequency greater than the zero crossings of the 50/60Hz line frequency?
Online Zero999
  • 0999
« Reply #23 on: November 09, 2017, 01:50:58 pm »
Perhaps the inverter generates a higher frequency than the normal mains?
Offline ogden
  • Country: lv
« Reply #24 on: November 09, 2017, 03:30:53 pm »
I would like to disagree to most of the LED bulb horror stories told here and ask everybody to think how it could work, not how it can fail. - Because after all original poster is doing good job - he is trying to make our world better place.
My two cents: 10W power is so low that I would not bother about sequential switching, any LED switching at all. I would run all the LED bulbs in parallel - to save on wiring in many installations and create 10W PWM-dimmable AC square wave inverter with input current limiter. Current limiter as safeguard against inverter overload and output short. Also it is worth to consider optional frequency control in 50-400Hz(?) range. Maybe it can help with some (too smart or too dumb) LED bulbs or reduce flicker. What's more or less clear here - lot of testing with various LED bulbs needed.
« Last Edit: November 09, 2017, 03:51:19 pm by ogden »
Online Zero999
  • 0999
« Reply #25 on: November 09, 2017, 04:46:59 pm »
Reducing the duty cycle using PWM might not work. If the DC:DC converter inside the LED has a smoothing capacitor, it'll take large current spikes on the rising edge of the pulse, with the magnitude and length of the pulse, depending on the impedance and the voltage on the capacitor. If the output of the internal DC:DC converter is constant current, then the power consumption of the LED will not change, until the PWM drops below a point. This might put extra stress on the lamp, leading to premature failure.
If the LED's DC:DC converter has no filter capacitor, then it will probably work, but it will flicker at double the mains frequency, unless the inverter works at a high frequency.
How do you propose PWMing the AC? It's not possible to do it in increments of less than double the mains frequency with SCRs. Another option is to use two MOSFETs back-to-back and chop the entire AC waveform at a much higher frequency, but that can lead to issues with RF interference and high surge currents, as mentioned above.
Phase control is an other option, in which case leading edge should be used with LEDs, rather than trailing edge, but again MOSFETs need to be used, rather than SCRs.
Offline ogden
  • Country: lv
« Reply #26 on: November 09, 2017, 06:12:31 pm »
My guess that it shall work with dimmable LED bulbs.
I would like to see any <= 10W low-end LED bulb (where OP is aiming at) which have constant current converter inside. Again we CAN find particular LED's which will not work with such approach, BUT again - we shall use common sense here too.
10W total power, 2.5W for each bulb. Again I would like to see - does LED bulbs really fail. After all hard edges can be easily filtered on the inverter output at let's say 1KHz cutoff freq or so.
Didn't I say about 50..400 Hz frequency control which could reduce flicker?
I did say "I would not bother about sequential switching, any LED switching at all". My proposal is to PWM-control inverter.
Too complex. Better chop inverter at higher frequency - as I proposed initially.
Square wave inverter cannot have any leading or trailing edge phase control because it's square wave.
[edit] Just looked at available PW controllers. UCC28089 looks like good choice. Additional op-amp and potentiometer needed to augment current sense for PWM-control.
« Last Edit: November 09, 2017, 06:29:10 pm by ogden »
Offline ogden
  • Country: lv
« Reply #27 on: November 09, 2017, 06:31:57 pm »
Obviously alternative option is digitally controlled inverter. Attiny24 is good enough for the job, especially considering it's 20x gain amplifier for ADC which is perfect match for current sense measurement.
Online Zero999
  • 0999
« Reply #28 on: November 09, 2017, 06:52:17 pm »
That depends on the bulb. Some dimmable LED bulbs look at the incoming waveform and adjust the LED current according.
Plenty, just look up LED driver ICs, using a search engine. Here's one example. Many more exist.
http://www.mouser.com/ds/2/302/SSL21082AT-843512.pdf
Possibly. It would certainly exceed the ripple rating of the input capacitor. Another issue is, if the LED bulbs are in standard fittings, people might replace them with other LEDs which aren't compatible. Look up capacative dropper LED, which certainly will fry if operated from too higher frequency.
Good idea.
The trouble is, he's already has the inverter and doesn't seem to be willing to redesign it or accept any help with the circuit, as he won't post it because it's proprietary information.
The only option if changing the inverter is not an option.
Actually, if could work, irrespective of the waveform, just delay the turn on, after
Good, if you're redesing the inverter.
« Last Edit: November 09, 2017, 09:41:06 pm by Hero999 »
Offline ogden
  • Country: lv
« Reply #29 on: November 09, 2017, 07:54:34 pm »
Existence of drivers does not prove that they are used in low end LED bulbs. You can more or less count on that. BTW you are showing one which for sure will work with "PWM dimmable square wave inverter"  8)
Ripple rating of the input capacitor?  :-DD BS. This lesson comes from bigclive LED academy? :) Crude LED bulbs have that poor series resistor for exactly that reason. - To reduce EMI and obviously ripple [inrush] current spike when minimum forward voltage of LED string is reached (check IV curve of the led). Most "dumb" LED bulbs conduct quite late in the AC cycle. Also we shall take in account that peak voltage of square wave inverter will be just 0.7x of AC mains peak for same RMS voltage output, so current spike difference could be minimal. In short - don't bother about wearing out capacitor or series resistor.
I would not be so certain. 400Hz is not that high frequency after all. Also remember about power budget we are talking here about. Most likely everything will be underpowered and very far from frying.
:palm:
Then somebody else will save the world :D
« Last Edit: November 09, 2017, 08:12:35 pm by ogden »
Offline orolo
« Reply #30 on: November 09, 2017, 08:23:57 pm »
Not high frequency at all. Take this cheap "3W" dropper bulb from Big Clive's Academy:
At 50Hz, the impedance of the 820nF is 3882 Ohms, so the RMS current is 52.5mA, and the 30V LED string dissipates a puny 1.6W, certainly underpowered for an alleged 3W bulb. Now crank the frequency up to 400Hz. The impedance is 485 Ohms, the current 359mA, and the power 10.68Watts. A x10 6.6x increase in power, and 3.3x more power than the rating. I'm sure Big Clive would approve  :) .
« Last Edit: November 09, 2017, 08:50:13 pm by orolo »
Offline ogden
  • Country: lv
« Reply #31 on: November 09, 2017, 08:48:20 pm »
At 50Hz, the impedance of the 820nF is 3882 Ohms, so the RMS current is 52.5mA, and the 30V LED string dissipates a puny 1.6W, certainly underpowered for an alleged 3W bulb. Now crank the frequency up to 400Hz. The impedance is 485 Ohms, the current 359mA, and the power 10.68Watts. A x10 increase in power, and 3.3x more power than the rating. I'm sure Big Clive would approve  :) .
As you did your homework, then I have no other option than to agree. - In case we talk about 100% duty cycle. But as I suggested not only PWM control but also input current (effectively output power) limiter, then RMS figures will be ok. Thou it is not good to 10x exceed current and I shhall agree that 400Hz is too much. Specs shall be revised  :-+
The following users thanked this post: orolo
  • Country: in
« Reply #32 on: November 09, 2017, 09:01:06 pm »
yes it does,inverter is at leat 10x more ....
hero999 inverter scheme is  fined tuned one . but the switcher i will draw later
« Last Edit: November 09, 2017, 09:19:05 pm by dave_j_fan »
  • Country: in
« Reply #33 on: November 09, 2017, 09:14:27 pm »
world better place.--yes ;D.... we will save on led lights power usage ,atleast cut bills to 1/3
poor gets backup power,solar lamps need smaller battery ..so on
but pwm dimming is of no use as hero999  outlined
the SCR gives flicker to 5watt LEDS , but 4watts work flawlessly. I will try with triac
REading this https://www.digikey.in/en/articles/techzone/2012/oct/avoiding-flicker-in-led-lighting-applications
« Last Edit: November 09, 2017, 09:22:40 pm by dave_j_fan »
Online Zero999
  • 0999
« Reply #34 on: November 09, 2017, 10:06:22 pm »
It's not that simple as PWMing the power. Read the datasheet, especially the part about  ton control.
Yes that's pretty much what I was getting at.
No one here is being negative for no reason. There are reasons why people here have recommended things such as a higher power inverter or 12VDC LEDs, but the original poster is either, unable or unwilling to implement them.
  • Country: in
« Reply #35 on: November 10, 2017, 05:56:35 am »
no worries with lowering of impedance here , smps bulbs only.people will  be instructed to buy standard LEDs all are SMPS
 ... we specify make and watt
there are Khz frequency inverters in market , running LEDs for long periods.
power-slicing : i call it .....its the TDM  ( time division multiplexing) of  AC  :-DD
Personally i try to avoid complexity in implementation. Bringing special chips for the job are last options.
I will use just 4017like  sequencing ICs so that parts are available everywhere .
i already have non-isolated driver based bulbs with similar chips . they too will be used in tests .
i may be noob here but Qn arises
where PWM dimming has come here ? we dont want to dim the lamps  and reduce power .
we want same light for a much lesser power
Offline mikerj
« Reply #36 on: November 10, 2017, 09:43:20 am »
You seem to be somewhat confused.  It's true the very cheap, low power lights use capacitive droppers, but when you are talking about a 10Watt LED lamp for a conventional lamp fitting then it is almost certain to be using a constant current switching regulator.  I took apart some cheap GU4 bulbs recently and even those used a switching regulator.
If it has a bridge rectifier and smoothing cap, then any attempts to dim the LED through e.g. phase control or PWM will greatly increase the peak current through the rectifier and the ripple current through the smoothing cap.
The OP is not saving the world, he's trying to  create a very complex solution to what appears to be a simple problem, and refuses to consider any other way of solving it.
The following users thanked this post: Connoiseur
Online Zero999
  • 0999
« Reply #37 on: November 10, 2017, 10:06:04 am »
I agree. Unless a special type of LED controller is used this won't work.
If you want to control the sequence of some lamps, then why not use a microcontroller? It will be more flexible than one of those old ICs and doesn't require as many components.
If it was possible to produce the same light for less power, then don't you think the LED lamp manufacturers would have already done that?
Your scheme will not give you the same light for less power. It will use more power to give you the same light and poorer reliability or slightly less power for much less light, again with poorer reliability.
Simply switching the LEDs on and off at a high frequency will not lead to any increases in efficiency, even if such a scheme were compatible with the integrated driver electronics. The human eye perceives the average brightness of a light flashing at a high frequency. If you flash a 10W bulb at 1kHz, equal time on and off, it will appear to give off the same amount of light as a 5W bulb.
In practise, if you tried to do that with a ready made LED, with a constant current DC:DC converter, the results will be unpredictable. It might: produce the same brightness but draw double the current, causing potential reliability issues, flicker horribly or just be dimmer.
Another factor is the non-linear response of the human eye. A 5W lamp may not appear to be half as bright as a 10W lamp, so even if you think you're successful by using half the power, for a slight drop in apparent brightness, you'll find the 5W lamp would have been a better option.
Offline mikerj
« Reply #38 on: November 10, 2017, 10:28:44 am »
If you have found a magical (and it would require magic) scheme to quarter the power consumption of an existing LED lamp for the same light output by manipulating the line voltage then you need to get a patent sorted out ASAP.
« Last Edit: November 13, 2017, 12:42:12 pm by mikerj »
Online Zero999
  • 0999
« Reply #39 on: November 10, 2017, 11:33:00 am »
The prices of solar panels and batteries are falling and are becoming a more attractive option, especially in areas with high electricity prices. There are other options, such as wind and energy from waste (look up biogas and gasification) which can be used to provide power on a small scale.
That article discusses LED DIMMING, using phase control. It will not help you achieve higher efficiency.
Offline Damianos
  • Country: gr
« Reply #40 on: November 10, 2017, 12:51:29 pm »
clarification :::
It is not a DIMMER
Of course it will do!
You can also expand it. At each output from the switcher, connect another switcher ... and, continuing this, you can have unlimited power/energy to lighten up the entire planet.
But not only this. If you start combining the outputs after a few billions of switchers, there will be plenty of power for trains, factories, homes, etc.
Still, if from some of the outputs re-feed the input, you can save and battery ... After start-up, you can remove it and your invaluable inverter!
Watch out! There will be many who will try to steal your designs ... ...
To be serious!
Are you insisting that a fast switching, with TRIACs or anything else, can cheat on the rules of physics?
Offline Connoiseur
  • Country: in
« Reply #41 on: November 10, 2017, 01:47:18 pm »
I would be glad to know the lm/W output of such a contraption. ::)
Boy! the OP should watch more free energy videos on YouTube. ;D
Offline ogden
  • Country: lv
« Reply #42 on: November 10, 2017, 09:10:04 pm »
Before you label someone as confused, you shall comprehend what he is talking about. I shall remind that main topic was not "capacitive droppers" as such but exceeding ripple rating of input capacitor and it's consequent failure. Even in case of constant current switching regulators square wave input shall not accelerate failure rate unless design is flawed.
[edit] Knowing target customer and assuming that he will buy 10W LED bulb with current switching regulator inside is kinda... uneducated thinking. If total power provided for 4 bulbs is 10 watts - then what's the point of paying for 4x10W bulbs?
If LED is designed as dimmable, it will work. Try to think of solution too, not only just dig up flaws. Actually latter is much easier.
Oh, Mr.Obvious. Do you know concept of sarcasm?
« Last Edit: November 10, 2017, 09:22:06 pm by ogden »
Online Zero999
  • 0999
« Reply #43 on: November 10, 2017, 09:50:12 pm »
[edit] Knowing target customer and thinking that he will buy 10W LED bulb with current switching regulator inside is kinda... uneducated thinking.
The power dissipation in the capacitor/inrush limiting resistor will be higher with a 50% duty cycle square wave, than a sine wave. If the inrush limiter has a negative temperature coeffient, then it might be fine, since the increased current might reduce the resistance enough to avoid the power dissipation getting too high, otherwise it could fry.
See the attached simulation. With a 500Hz 50% duty, 325V (the peak voltage for 230VAC), the power dissipation in R1 (the surge limiting resistor) will be 500mW. When V1 is changed to a 500Hz square wave, the power in R! increases to over 2.5W. I'll attach some screenshots later.
It might work or it might not. It depends on how the dimming is implemented. With the IC data sheet I linked to earlier, it certainly wouldn't work.
Unfortunately sarcasm often gets lost in the depths of the Internet.
« Last Edit: November 10, 2017, 09:52:11 pm by Hero999 »
Offline ogden
  • Country: lv
« Reply #44 on: November 10, 2017, 10:55:51 pm »
Did not able to interpret .asc file provided, sorrry. Your beginners error is that square wave inverter will not output "325V (the peak voltage for 230VAC)" but 230VAC RMS voltage which is essentially 230V peak. So, RMS power dissipation in R! in case of square wave will be identical. Where's the catch?
[edit] Actually I was beginner here, apologies. 230V peak of square wave inverter at 100% duty cycle will give same power as RMS 230VAC only for resistive loads. LED with rectifier inside needs 325V peak disregarding it is sine or square wave.
Detailed explanation please [grin].
« Last Edit: November 14, 2017, 04:45:37 pm by ogden »
Online Zero999
  • 0999
« Reply #45 on: November 11, 2017, 12:06:14 am »
No.
For a start, in order to work properly, the inverter would have to output a voltage of 325V, since that what will be on the capacitor, after the rectification of the 230VRMS mains, which has a peak voltage of 325V. Don't believe me? Connect a 12VAC transformer to a bridge rectifier and capacitor. You'll find that the voltage on the DC side, is equal to about 1.414 times the AC side, minus the diode losses. Even if the voltage were reduced to 230V, the power dissipation would still be higher, than for a sine wave.
Did you refer to the data sheet, paying attention to the part about  ton control, pin 8, the TONMOD pin? The dimming function is dependant on the timing of the sine wave on the input to the rectifier.
« Last Edit: November 11, 2017, 12:12:21 am by Hero999 »
Offline kalel
« Reply #46 on: November 11, 2017, 12:07:18 am »
As (little) as I know, multiplexing does decrease the brightness we perceive, since each LED is only on for some time. Even a single LED switching "on off" faster than we can see will produce less light than a constantly on LED, because it will be some "on and off" output average that we see rather than just "on" output.
As far as capacitive droppers, I'm almost certain I have seen capacitive droppers in cheap claimed 9/10W LEDs. I haven't measured the wattage to see what it outputs really, but they are quite bright, and don't last too long (up to a few years). Sometimes the LEDs get burned (lack of proper heat-sinking?) - they first get darker spots, still work for a while - and finally fail, sometimes the electrolytic capacitor fails (it does get moderately heated, I don't know how a better capacitive dropper design could mitigate this issue).
« Last Edit: November 11, 2017, 12:09:01 am by kalel »
Offline ogden
  • Country: lv
« Reply #47 on: November 11, 2017, 02:40:40 am »
Why you are using 50Hz for sine and 500Hz for inverter?
[edit] Anyway - you just completely ignore all the other "specs" of the project including 10W power limiting of inverter output, it's duty cycle which for sure will not be 100%, you put hi-voltage 47uF capacitor into low cost LED (!).
Also this:
is not detailed explanation but more like trolling.
« Last Edit: November 11, 2017, 10:05:25 am by ogden »
  • Country: in
« Reply #48 on: November 11, 2017, 10:12:00 am »
The point of getting reduced light like 5Wled bulb from 10w  with 1khz frequency is not valid , in khz range the LED gives almost same brightness.I have tested it, with few brands like hevells, philips ..
For the point "flicker" "dimmer"   is also not fully true .
my Jig already achieved same light for 4W LED . I have tested with SCR as active element .
yes the 5W led gived a breathing like fliker mey be because SCR have reduced the voltage .
 I have reduced the off period to 1sec and the SCR switch is giving flicker , means
..TRIAC tests will ... hopelfully make the jig work
The discussion is very informative. I am going baby steps way to make the jig flicker free .
Jig will feed from a small diy inverter .... DC current i will measure and find the truth .
 remember JOULE ringers running 10LED bulbs ...so possibility is always there
  • Country: in
« Reply #49 on: November 11, 2017, 10:17:41 am »
 ::) will see ...
 for your information i have a DC led tube , i added PWM and reached 12hours light ... originally it was giving 3-4hour
 dont bring physics if you dont know pulsed and switched led lighting saves lot energy .
 however i  have less test knowledge on AC so asked experts
  • Country: in
« Reply #50 on: November 11, 2017, 10:21:25 am »
 ::) will see ...
Offline ogden
  • Country: lv
« Reply #51 on: November 11, 2017, 12:01:49 pm »
You assume you are getting same light output while LED is PWM-dimmed, but you are not. Do you have lux meter to measure light output? If not, then take two identical LED bulbs, run one w/o PWM and another with PWM at the same time so you can compare brightness. It will differ for sure.
  • Country: in
« Reply #52 on: November 11, 2017, 01:28:38 pm »
it may be slight reduced but probably reducing heat loss it maintains good amount of intensity.The tube is  very good usable light for small kitchen.
I have even distributed Khz range  power boosted lights . 12v to 230v . pulsed mode maintains nearly same intensity in bulbs .My observation.
 I junked 3 circuits for lower light , finally found super bright one
Online Zero999
  • 0999
« Reply #53 on: November 11, 2017, 04:17:33 pm »
Because an off the shelf LED lamp will be designed for 50Hz operation, not 500Hz. Think about it.
It's typical for the input stage of a mains powered LED. Do some research, before making stupid comments.
Also this:
Don't accuse others of trolling, just because you don't understand something.
Have you measured the power consumption?
Have you done any objective measurements of the brightness, using a meter, rather than ones eyes?
Bear in mind the eyes can easily be fooled. A 10W bulb won't look twice as bright as a 5W bulb.
« Last Edit: November 11, 2017, 04:25:36 pm by Hero999 »
Offline ogden
  • Country: lv
« Reply #54 on: November 11, 2017, 06:35:32 pm »
Oh, thank you for schooling. Actually I wanted to know where 500Hz for inverter came from
47uF typical for low cost LED bulbs? - Show your data.
Then explain in details so we can understand why particular chip will work from dimmed 50Hz sine wave but will not work from 50Hz PWM square wave. I want to know which part of mentioned datasheet explains that. So I ask you again: please give detailed explanation.
Online Zero999
  • 0999
« Reply #55 on: November 11, 2017, 07:51:59 pm »
  • Please read the thread from the beginning. The original poster intends to drive a bulb rated for 50Hz, using an inverter with a much higher frequency square wave. It should work with a continuous duty cycle +/-230V to 325V square wave, as long as the frequency isn't too high for the diodes in the bridge rectifier to switch, but not for a square wave with 50% duty or modified sine wave.
  • The value of the filter capacitor is not important. It was an example of a typical input stage of an LED lamp. Bridge rectifier -> surge limiting resistor -> capacitor. The idea was to demonstrate, that powering it from a 50% duty cycle square wave can cause excessive power dissipation in one of the components. Another issue is, this may work on the bench but prove unreliable in the field. Often overstressed components don't fail immediately but blow up much later.
  • The dimming function of that is dependant on the mains frequency being near 50Hz, 60Hz or whatever the circuit is designed for and changing the frequency will mess it up. Don't forget that he doesn't have any control of the circuit being used to power the LED, only the voltage input to it. Another issue is he doesn't want to dim the LED. He wants to power it at full brightness, whilst reducing the power consumption: an impossible feat!
« Last Edit: November 11, 2017, 08:36:41 pm by Hero999 »
  • Country: in
« Reply #56 on: November 11, 2017, 07:53:26 pm »
Also this:
i respect that new information ... i stated  by observation of the light in the room not just bulb on table.
Today 2 channel test success with 5Watt and 4watt .the 5watt leds had flicker,todays test used TRIAC. It is maintaining good brightness.
may be 3-4channel mux will be ok.
all inverters i have given to poor
i will get parts and test 1bulb inverter to drive 2 bulbs.technically it must work because  230V test is promishing .
Just frequency is in khz range .
« Last Edit: November 11, 2017, 08:20:52 pm by dave_j_fan »
Offline ogden
  • Country: lv
« Reply #57 on: November 11, 2017, 11:48:50 pm »
I can say the same to you because:
1) I am not original poster
2) I suggested inverter with tunable frequency 50-400Hz range and tunable duty cycle, with input current limiter which will essentially limit output power to nominal.
3) you jumped on me when I said:"I shall remind that main topic was not "capacitive droppers" as such but exceeding ripple rating of input capacitor and it's consequent failure. Even in case of constant current switching regulators square wave input shall not accelerate failure rate unless design is flawed."
4) Then you came up with LTspice design where you conveniently (for you) ignore fact that inverter frequency, output voltage and duty cycle can be adjusted to meet design requirements one of which would be "do not accelerate LED bulb failure".
I suggest you to run your inverter LTspice not with 50% duty cycle, but 100% which essentially is DC coming out of bridge rectifier, tune peak voltage so LEDs dissipate identical power compared to AC sinewave design and only then check power dissipation in the inrush limiter resistor. Maybe then you will understand what I did mean by saying "Even in case of constant current switching regulators square wave input shall not accelerate failure rate unless design is flawed.".
 :palm: well then dont change it. remember? - I did leave 50Hz option in my offer.
« Last Edit: November 12, 2017, 12:15:04 am by ogden »
Online Zero999
  • 0999
« Reply #58 on: November 12, 2017, 12:17:25 am »
No but you can read what they've written.
The original poster mentioned using a higher frequency, than 50Hz mains first.
https://www.eevblog.com/forum/beginners/10watts-for-all-4-will-it-work/msg1344171/#msg1344171
No one jumped on anyone. The point was that there are a variety of different designs of LED lamps. It's impossible to know what they'll do when you change the input frequency/duty cycle, without lots of prior testing or reverse engineering. What's worse is that with a standard fitting, someone could easilly change the lamp to an incompatible one, which could blow up.
Then you came up with LTspice design where you conveniently (for you) ignore fact that inverter frequency, output voltage and duty cycle can be adjusted to meet design requirements.
No, I modelled the typical input stage of an LED lamp and explained why it can overheat if you try to dim it by PWMing the input voltage.
I know and even said previously that it will work off DC, but what's the point when with 100% duty cycle, there will be no reduction in power consumption or brightness?
https://www.eevblog.com/forum/beginners/10watts-for-all-4-will-it-work/msg1345097/#msg1345097
Varying the supply voltage (whether AC or DC) will not change the brightness or power consumption of some LED lamps, because they contain a constant current driver, which tries to keep the current through the LED chips the same, despite changes in supply voltage.
Good and better made it a pure sine wave, which is a more complicated inverter design, just to be sure it works.
Please post some schematics of what you've already done.
Have you tried it with a variety of different LED lamps? Is there a risk the user might do something silly like replace the LED lamp with an incandescent or compact fluorescent?
« Last Edit: November 12, 2017, 12:22:10 am by Hero999 »
Offline ogden
  • Country: lv
« Reply #59 on: November 12, 2017, 01:02:38 am »
I did. On the other hand, you did not read what I wrote.
How many times I shall remind you that you opposed me, not original poster?
If everything is designed correctly - nothing will blow up.
Well... as I indicated - you did it wrong.
DC is starting, "calibration point" - for you to correct your LTspice LED bulb simulation. After you tune design to work correctly off DC, you will see that it will not tend to blow up when PWM'ed to lower than 100% duty. Proper dimmable square wave inverter will not blow up LED bulbs faster than triac dimmers. This is what I am telling you all the time  8)
Varying the supply voltage (whether AC or DC) will not change the brightness.
You are kidding me or what? Please re-read it carefully: "tune peak voltage so LEDs dissipate identical power compared to AC sinewave design and only then check power dissipation in the inrush limiter resistor".
Actually I believe that original poster have better option: instead of designing, manufacturing and selling inverter & fancy 4-led sequenced to end-customers, better just sell them 12V LED bulbs  :popcorn:
« Last Edit: November 12, 2017, 09:02:17 am by ogden »
Offline Damianos
  • Country: gr
« Reply #60 on: November 12, 2017, 01:36:38 am »
 ::) will see ...
[... even if you have mixed up the quotes and you are answering to yourself!]
Oh! I know a lot of things, but I keep some secrets!
The nature was born before the LEDs and switchers, so does not know about them!
Also, I know that half of the power on LED lights hidden somewhere and waiting for an enlightened to reveal it!
I work on a similar project but much more advanced. As you know LEDs are also light detectors, they generate voltage and current when light hits them. Using a suitable mirror and switching them fast, they produce energy from their own light! The only unsolved problem is synchronization of switching with the time that the light beam needs to travel up to the mirror and return back. As I don't know enough about pulse and switching circuits, I use a pushing switch manually. I need some help to slow the switch contacts, as they are faster than light ... ...
  • Country: in
« Reply #61 on: November 12, 2017, 03:11:55 am »
apart from law of physics  and ranting why it wont work.Why not  some members try it..$5 in parts wont hurt
i am not saying physics is bypassed but telling non conventional ways to light leds.The work by lidmotor in energetic forums
show that with less watt also you can get same brightness.Experiment ,change,try.
mcu> 4017>triac
circuit is as simple as that
for people fighting on "what will work" why not come with own test jig post real reading of ac power
while running battery drain tests in my inverters i checked some random things and found adding 100uH inductor in series on ac side  , or 1uf 400v cap in series
the battery drain is reduced.Be practical you will discover some secrets
is the objective is to save power ?
Not exactly but if we can good . First target is to reduce loading of the inverter.
25W inverter if it can run 50w leds ....we save lot on per inverter cost .common people benifitted with  econmical inverters
getfull house lights for too lowspending .
They need small battery that further reduces cost .
« Last Edit: November 12, 2017, 03:16:37 am by dave_j_fan »
Offline ogden
  • Country: lv
« Reply #62 on: November 12, 2017, 09:11:09 am »
Did you wear tinfoil hat while discovered those secrets? BTW you can reduce battery drain even further by switching your inverters off. Such experiments that just measure consumed power without measuring resulting light output are useless.
Online Zero999
  • 0999
« Reply #63 on: November 12, 2017, 01:59:43 pm »
Yes, it did. It was wrong and someone else, as well as myself, corrected it.
We did inform the original poster that this could be an issue and don't take things so personally: if you post something which is incorrect, people will correct you.
And operating an unknown LED lamp from a PWM square wave is bad design, so there's a risk it will blow up. Even if you manage to optimise the design for a particular brand/design of LED lamp, it's in a standard fitting, so there's a risk someone might change the bulb for an incompatible one, which will blow up.
How is it wrong? If I made any errors, please point them out and correct them. Bear in mind there are lots of different LED lamp designs. .  .
Here's another mains powered LED lamp design. This time I've posted the full schematic. It's worse because it has no inrush limiter. C1 and D1 to D4 may be able to handle the occasional inrush, but PWM this and it will be destroyed.
https://www.alibaba.com/product-detail/Proxy-AC-LED-Driver-IC-FT838RNA_1624190417.html
No, there is a risk it will blow up. Suppose the circuit can safely run off 230VDC safely, without any problems, it does not mean that it can run off 230V with 50% PWM safely. Every time the power is applied, a large current flows through the surge suppression resistor to charge the capacitor. The bulb will only be designed to be turned on occasionally, not turned on and off, from an abrupt square wave hundreds of times per second.
PWM is only good for controlling the power delivered to linear loads such as resistors and motors. It is no good for non-linear loads, such as switched mode power supplies, which are often found in modern LED lamps. Just because you can PWM an LED + series resistor, it doesn't mean you can PWM a mains LED lamp.
And how are you going to check the power dissipation in the inrush limiter, inside the LED bulb, without dismantling it? Bear in mind that it's difficult/impossible to open some LED bulbs, without damaging them in the process  and as mentioned above, the bulb is in a standard fitting, so the user might replace it with another one which won't work the same way.
I agree. He's been told that plenty of times.
mcu> 4017>triac
You'll get a more positive response if you actually posted schematics showing what you're doing.
If you really are intent on saving the planet, rather than making money, then you shouldn't keep anything secret. Spread the information, so others can join your quest to save the planet.
« Last Edit: November 12, 2017, 03:52:47 pm by Hero999 »
  • Country: in
« Reply #64 on: November 12, 2017, 05:22:48 pm »
no one should come here  after few shots of https://i.pinimg.com/736x/8d/e1/cf/8de1cf0f2067f77759f1023c75d48e38--whisky-jack-jack-daniels-single-barrel.jpg
Hero999,
Here I am donating the billion dollars ..!  :P
 * Simple LED sequencer  using a 4017 counter.
 * The 4017 is used to save pins on the arduino.
 * Developed by daveJ Fan
/* PIN used to send clock pulses to the counter. */
int clockPin = 2;
void setup() {
  pinMode(clockPin,OUTPUT);
 * Sends a clock pulse to the counter making it advance.
void clock() {
  digitalWrite(clockPin,HIGH);
  delay(1);
  digitalWrite(clockPin,LOW);
void loop() {
  /* Send a clock pulse to the counter. It makes the counter advance
     causing the current LED to be turned off, and the next one to be
     turned ON */
  clock();
  /* Wait for 30 ms. */
  delay(30);
well code is copied and at the output  LEDS there is a opto-TRIAC
Its too easy  .
Even simple 555 will work with this ..
you have motivated me  8) to do the right thing  :-+
« Last Edit: November 12, 2017, 05:31:01 pm by dave_j_fan »
Online Zero999
  • 0999
« Reply #65 on: November 12, 2017, 05:28:47 pm »
I take it the IC on the right hand side is the CD4017?
Why not just use the Arduinio? There's no need for the CD4017.
  • Country: in
« Reply #66 on: November 12, 2017, 05:38:00 pm »
arduino will be retired   ^-^ to cut cost , adding bjt /555 later
yes , IC on right is 4017
  • Country: in
« Reply #67 on: November 12, 2017, 05:47:32 pm »
for people with interest the   johnny aum night light. is an example of getting very nice light with 51Milliwatts power, driven LED is 2.8watts  ! Point is there are many possibilities
http://www.energeticforum.com/296163-post38.html?s=03f790b602cb7fbdb175e0416c3a83d4
Offline ogden
  • Country: lv
« Reply #68 on: November 12, 2017, 06:02:30 pm »
Keywords here are dimmable LED bulb and LED bulb that tolerates triac dimmers. Please read below.
Error 1) You compared dissipation of each inrush limiter resistor without showing dissipation in each "LED equivalent" made out of current sink. For fair comparison they must be equal. So basically useless comparison.
Error 2) You compared 100% duty cycle (undimmed) AC mains to 50% duty cycle square wave. Again useless comparison.
Right. Those which will fail from leading-edge mode triac dimmer input most likely will fail from square wave too. - As I said already multiple times that "Proper dimmable square wave inverter will not blow up LED bulbs faster than triac dimmers."
Well, thank you. For balance I will share one much more interesting - from engineering point of view.
https://www.fairchildsemi.com/product-technology/direct-ac-drive/
When dimmed from leading edge mode triac, sharp pulse up-to full Peak-Peak voltage of AC mains each half-cycle will be applied to it while at particular dimmer setting:
Further reading:
http://www.ledsmagazine.com/articles/print/volume-8/issue-6/features/led-lighting-must-work-with-legacy-dimming-technologies-magazine.html
That one particular LED bulb controller you gave datasheet for, does support triac dimmers, both leading and traling edge. Hows that?
Crlt+click on waveform  :-DD
Yes, I did talk about your LTspice simulation, not LED physical bulb.
Online Zero999
  • 0999
« Reply #69 on: November 12, 2017, 07:01:11 pm »
That's all fine, until the user replaces it with a non-dimmable lamp.
What do you mean by LED equivalent? The power rating of one of the components is exceeding its rating by a factor of 5, when run on a 50% duty square wave vs the sine wave it was designed for!
I agree so perhaps my simulation, wasn't so incorrect after all. It demonstrates why a non-dimmable LED will fail, when operated from PWM.
Further reading:
It supports TRIAC dimmers, not PWM! They are not the same thing!
Ok it might not blow up but flicker, when run off the wrong frequency square wave, rather than a sine wave. Still not good.
Why not simply use a 50 or 60Hz sine wave inverter and a proper dimmer circuit for a dimmable LED lamp, rather than risking failure with a square wave, at the wrong frequency? That's a much better solution. Use components, as they're designed to be used, within their specifications. Attempting otherwise, only leads to trouble, further down the road.
By the way, thank you for posting the second link. It might help to explain to the original poster, why his LEDs aren't getting any dimmer.
What do you mean by?
I re-read it several times and it makes no sense!
The LTSpice simulation was an approximation of an LED driver circuit, run off a bridge rectifier and capacitor. The LED is modelled as a current source, but in reality, it will be a constant power circuit, i.e. a switched mode power supply. The input current will increase, as the voltage on the capacitor falls  (down to a certain point of course) which should theoretically, increase the power dissipation on the surge limiting resistor, as the supply voltage is reduced. The end result will be the same: PWMing it will cause no dimming and premature failure.
Another option is a ring oscillator. I designed a PCB for one awhile ago, as a learning exercise.
https://www.eevblog.com/forum/beginners/my-latest-eagle-pcb/msg10497/#msg10497
By the way, no that would not make mains LEDs use less energy, but keep the brightness the same. They will either get dimmer, or the controller IC inside the mains LED lamp, will increase the current draw, to keep the brightness constant. If the latter happens, there's more risk of premature failure of the LEDs or inverter, used to drive them. You need to invest in a power meter. One which will work with a square wave and at different frequencies than the standard 50 or 60Hz mains. Measuring the voltage and current simultaneously and applying Ohm's law doesn't give you the true power, although it will give you a good idea of whether the inverter's output current rating is not being exceeded.
I have a non-dimmable mains LED lamp. I've tried using it with a phase controlled dimmer. The brightness stays constant, until the dimmer setting is reduced past a certain point, then it starts flickering and stops working. I have not measured the power consumption with the dimmer, but I'm pretty sure that it's not using less power, with the dimmer, than without it. I didn't test it for long, because it's likely it would have damaged the dimmer.
That looks like a Joule thief. A very old circuit. It's totally different to what you're doing, because the LED's driver has been removed, so it's powering a bare LED. That circuit doesn't magic 2.759W from nowhere! The 2.8W bulb is clearly running at a fraction of its rating brightness, because the current through it is much lower than the rating. It's true that driving an LED, at a lower current, than its maximum rating increases the efficiency, up to a certain point, but it works out very expensive to buy LEDs rated for much more power, than they'll be driven with, so LED manufacturers won't do it. How many people would by a 1W LED which costs nearly as much as a 10W LED?
  • Country: in
« Reply #70 on: November 12, 2017, 07:40:08 pm »
superb option , how to make it a variable freq one  , adding 10K Vr in feedback ?
I know abt JT and made 5 types some time back , but the circuit is not a exact JT  as there is no twocoils with 3 pint connection than itz a series connected coil type .
What is interesting is 51milliwatts !! for 75% 'usable light'  ,this gives me idea of pushing the 9W for all room light  with this type circuit. This type of boosters will run well in shops and 1student room alikes .
Online Zero999
  • 0999
« Reply #71 on: November 12, 2017, 08:14:56 pm »
The values of all of the 10k resistors need to be varied, which is probably not practical.
There are several different variants of the classic Joule thief circuit. In this case, because both of the coils are connected in series and are magnetically coupled, they behave like one coil.
Don't let the picture fool you. It isn't using 51mW to produce 75% of the light of a 2.8W lamp. It's an illusion.
Offline ogden
  • Country: lv
« Reply #72 on: November 12, 2017, 09:39:16 pm »
Checked your LTspice design and agree - "dimmer incompatible" LED bulb which is based on constant current IC, most likely will fail due to overheat.
They are indeed. PWM synced to AC mains phase and frequency can do same thing as triac dimmers do. PWM does not relate only to DC chopping. You can do PWM on any waveform you want.
If you feed dimmer-compatible LED bulb IC with 50Hz(!) square wave - it will sync to it. When you PWM-chop 50Hz bipolar square wave coming out of push-pull or full-bridge inverter, then dimmer-capable LED bulb IC will happily detect dimming. Am I missing something here?
Online Zero999
  • 0999
« Reply #73 on: November 12, 2017, 10:13:39 pm »
PWM has a similar effect to phase control but it is not the same thing. PWM isn't normally used in AC circuits, because it's much easier to use phase control and when it is used, it's usually referred to as burst or full-wave duty-cycle control. The PWM is synchronised to a much lower frequency than the mains, causing it to get chopped up into blocks of full cycles, followed by off periods. The ratio of full mains cycles, to off periods is the duty cycle.
It looks like this:
Obviously this is no good for lighting, because it will flicker, unless the AC frequency is very high, so it's used for heating. The main advantage over phase control is, switching only ever occurs at the zero crossing time, there is no abrupt switch on/off of current, so it's less noisy.
If the sine wave is PWMed at a much higher than its fundamental frequency then it will be chopped up into tiny pieces and look like the right of the image below. On the left shows phase control, which many people confuse with PWM.
http://www.edgefxkits.com/ac-pwm-control-for-induction-motor
I imagine it's very noisy, which is why I've not seen it in real life, only on forums.
As far as powering a dimmable LED lamp, which is designed for use on 230V 50Hz AC, from PWM DC is concerned: it may, or may not work. To stand the highest chance of success, use 100Hz or 120Hz, rather than 50Hz, because that's what the LED driver IC will see on the DC side of the rectifier.
Offline ogden
  • Country: lv
« Reply #74 on: November 12, 2017, 10:32:34 pm »
Indeed dimming is right word for AC mains phase control but principles to PWM is the same - as I already explained. So to say "Dimming is not PWM. Period." is not quite correct as well.  :popcorn:
It is. Modern PFC uses hi-freq PWM for AC mains power factor correction. Waveform looks like you are showing "the real PWM control of AC".
You (again) ignored what I say. Reminder in bold: 50Hz bipolar square wave coming out of push-pull or full-bridge inverter after rectification will look like pulsing 100Hz.
« Last Edit: November 12, 2017, 10:34:12 pm by ogden »
Offline ogden
  • Country: lv
« Reply #75 on: November 12, 2017, 11:26:25 pm »
Anyway soon all LED bulbs will have no switching converters or bulk capacitors which are main contributors to price and failures too.
From inside they will look like this:
Not like this:
Such design with PF approaching 0.98 acts like resistive load and will have no problems to work from any waveform you drop at it. Just don't exceed voltage rating ;)
Offline kalel
« Reply #76 on: November 13, 2017, 01:34:31 am »
If I have seen it right, it looks like a circuit with an integrated driver (I don't know what else to call it), similar to the video below. Don't those designs experience a lot of flicker as is?
There might be new designs that solve the flickering, or perhaps what you showing in the image is a different type of circuit all together.
« Last Edit: November 13, 2017, 01:36:11 am by kalel »
Offline ogden
  • Country: lv
« Reply #77 on: November 13, 2017, 07:53:34 am »
Different indeed.
Exactly opposite.
They are based on AC-direct regulation IC which progressively switches on each of 4 LED strings until all are illuminated at the mains voltageโ€™s peak. Note that for simplicity circuit below shows just 3 strings. This allows to "cover" with illumination nearly all the AC mains cycle. Resulting light is nearly flickerless.
Article here: https://www.electronicsweekly.com/news/why-not-direct-ac-drive-your-led-string-2016-04/
I already mentioned ON Semi FL77904 which is single chip 4-string IC requiring few small passives, bridge rectifier and that's it. Power factor better than 0.98(!). It is beauty if we can say so about engineering.
http://www.onsemi.com/PowerSolutions/product.do?id=FL77904
« Last Edit: November 13, 2017, 08:07:27 am by ogden »
Online Zero999
  • 0999
« Reply #78 on: November 13, 2017, 08:50:45 am »
Dimming is not the right word for AC mains phase control, since it can be used for other purposes than lighting, such as controlling the speed of motors and the power output of heaters.
Not quite. Power factor controllers, PWM the DC side of the rectifier, not the AC side.
Oh I see what you meant now. No I wouldn't  recommend doing that. Chopping the output of the inverter, would result in much higher frequency components, which might not play nicely with the LED driver, unless you're talking about something else.
It would be better to rectify the output of the inverter, then PWM that at 100Hz.
Offline ogden
  • Country: lv
« Reply #79 on: November 13, 2017, 11:27:46 am »
Again you assume inferior design.  :-//
All UPSes with "simulated sine" output have what we call here "chopped inverter". Yet they somehow pass EMC regulations, computers are happy with such waveform, most likely LED bulbs will too. Chopping happens on primary side of the transformer, output have just quite simple (L)C filter.
Having proper snubbers on primary and some filtering on secondary winding of the transformer, output looks not that bad at all (from hi-freq ringing point of view):
https://www.hardwareinsights.com/database-of-ups-output-waveforms/
Such waveform will cause much worse inrush current problems than modified sine wave, drooper-capacitor LED bulbs most likely will be very unhappy about such input too.
[edit] When you feed such modified sine into your "LTspice LED bulb", you will see that 10ohm resistor dissipates only ~1W at full power and ~1.1W when 50% dimmed. This BTW is just 2x exceeding "pure sine rating" 8)
« Last Edit: November 13, 2017, 12:02:58 pm by ogden »
Online Zero999
  • 0999
Re: 10watts for all 4, will it work
« Reply #80 on: November 13, 2017, 12:28:45 pm »
Now you're making an assumption too: that output of the original poster's inverter is a modified sine wave. You've also forgotten that the original poster doesn't want to or cannot change the inverter.
Unfortunately we have to make assumptions, in the absence of all the information. The original poster has not posted a schematic or an oscillogram of the output waveform of their inverter, so we don't know the full story.
DC PWM will  be no worse or no better than a modified sine wave, for the circuit I simulated in LTSpice. Yes a capacitive dropper won't work from PWM DC because, it will be blocked by the capacitor.
Yes, still not good though and could lead to reduced reliability.
« Last Edit: November 13, 2017, 12:33:02 pm by Hero999 »
Offline ogden
  • Country: lv
« Reply #81 on: November 13, 2017, 12:39:27 pm »
You'v forgotten that you discussing to me here, not original author. I do not share authors plans, provided mine in return. Obviously when I say something about inverters and so on, I am considering my view, not original posters plans. That's it. Tired of reminding. Bye.
Online Zero999
  • 0999
« Reply #82 on: November 13, 2017, 12:49:26 pm »
And you've forgotten that this is not your thread! By barging in to some one else's thread, you've derailed it and created pages of useless information, which is totally irrelevant to the original poster's question, which is not helpful.
If you wanted to discuss your inverter/LED lamp design, then you should have created your own thread, rather than derailing someone else's!
I apologise to the original poster for playing my part in this. I should have recognised this and stopped responding to you, long ago.
Offline mikerj
« Reply #83 on: November 13, 2017, 01:18:05 pm »
Not a single person has stated such nonsense as "Dimming is not PWM. Period."  If you have to resort to making things up then your argument is a lost cause.
As for you PWM AC waveform doubling the power dissipation in the 10R resistor, why do you think this is acceptable?  Do you believe that mass produced LED lamps are all sufficiently over-engineered that you can ignore this?
Offline ogden
  • Country: lv
« Reply #84 on: November 14, 2017, 01:06:42 am »
So you say that someone who offers alternate solution for consideration, actually creates "pages of useless information, which is totally irrelevant to the original poster's question". With emphasis on "totally irrelevant".
Are you serious? How many times did you offer something that differ from original poster's plans? - Shall we count? Or maybe you did not offer anything useful, just denied everything you did not agree to?
« Last Edit: November 14, 2017, 02:06:25 am by ogden »
Offline ogden
  • Country: lv
« Reply #85 on: November 14, 2017, 01:29:16 am »
Well, Hero999 stated: "It supports TRIAC dimmers, not PWM! They are not the same thing!". In my opinion saying "Dimming and PWM are not the same thing!" (pay attention to exclamation sign mark) is the same as "Dimming is not PWM".
I did agree that this is not acceptable. Perhaps you missed that (as usually happens here in this forum thread):
« Last Edit: November 14, 2017, 02:16:59 am by ogden »
Offline ogden
  • Country: lv
« Reply #86 on: November 14, 2017, 01:45:38 am »
Actually I did good service to thread - created special attention to square wave inverters which are not compatible with some LED bulbs. I doubt that 5$ inverter mentioned by original poster, is pure sine wave one. Disregarding this fact you did offer your ring oscillator. No further comments...
« Last Edit: November 14, 2017, 02:25:20 am by ogden »
Offline dave_j_fanTopic starter
  • Country: in
« Reply #87 on: November 14, 2017, 05:20:21 am »
its ok Hero999, not your fault
I request the other poster  to  keep discussion to target the plan of mux on the AC line .
Let us not go deep into LED drivers and million inverter design. Then it will be like making a chair for 2yo to 90yo with a size that fits all .
We are engineers , seek to make viable products not science explorer .
-some good news here!!! -
 The plan works by unloading the inverter  8)
 a small inverter that used to flicker after 15watts now happily taking 25W , pretty amazing bright lights .
 i am too lazy to make lux meter  but  compared lightof 1 bulb with MUX and without MUX .
 Did it save power ?
 Not much,9watter was pulling  800mA  DC
 25watts load was showing 600mA / per 5watts  drain
 did the lamps over heat ?
 NO
 i wish someone could fund me for a patent!  :-\
 Many experts cant achieve to a solution because they lose focus ,  so it is better the discussion can limited to reach some  solution
  these are the  parameters for a BETA of the AC MUX
- Approx square wave ( a little different in my case  ) inverter , take frequency 10khz
-target is to get atleast 4 bulbs on 10w inverter
-all bulbs are SMPS ( no future tech and , cap dropper)
There are 2 ways
-simulation model
-real one
Second one will save time initially
« Last Edit: November 14, 2017, 05:29:53 am by dave_j_fan »
Online Zero999
  • 0999
« Reply #88 on: November 14, 2017, 08:53:54 am »
You didn't contribute any schematics, simulations or ideas to the thread. I posted a simulation which demonstrated what happens to the input stage of a mains LED, when driven with various waveforms. All you did was derail the thread with nonsense about it being fine to overstress parts, dimmable lamps and PWM and phase control being the same thing.
 Did it save power ?
 NO
There are 2 ways
-simulation model
-real one
You can't rely on your eyes to make quantitative measurements. A lux meter is the only way to perform objective tests.
I suggest doing long term trials. Just because they're SMPS, it doesn't mean their reliability won't be affected.
Have you looked at the output current and voltage waveform of your inverter with an oscilloscope?
Offline ogden
  • Country: lv
« Reply #89 on: November 14, 2017, 11:49:33 am »
I did. Very early in this thread I said: "I would run all the LED bulbs in parallel - to save on wiring in many installations and create 10W PWM-dimmable AC square wave inverter with input current limiter. Current limiter as safeguard against inverter overload and output short. "
You posted simulation which uses inverter of infinite power just to prove your uneducated point, ignoring fact that original poster mentioned 10W (in the topic of this thread). If we take in account limited power of the inverter which can sustain let's say 1A max output current, then "parts overstress" picture changes dramatically and inrush resistor dissipates just 155mW average during 1sec of simulation which is few times less than nominal which you put at 500mW. Simulation attached.
It is actually you who are spilling nonsense all over this thread by literally attacking me with sentences like this, providing misleading "facts" using simulations that proves nothing more than how incompetent or careless you are. I do not recall saying "it is fine to overstress". I said - if everything is designed properly then nothing will blow up meaning there will be no parts overstress.
« Last Edit: November 18, 2017, 06:19:01 pm by ogden »
Offline ogden
  • Country: lv
« Reply #90 on: November 14, 2017, 07:52:04 pm »
For those who still believes that square wave is much worse for LED bulb than sine, I offer to consider that bulbs shall be designed to withstand power-on at any phase angle of AC mains including max peak voltage, otherwise they will blow-up nearly every power-on. Best and worst case dissipation of inrush resistor results for AC mains sine attached. Best case obviously - to show that it gives result we already know, 0.5W @ 1sec.
Worst case is much more interesting.. because it's 2.49W is pretty close to "LED blown-up by square wave" simulation result of 2.54W  :-DD
« Last Edit: November 14, 2017, 08:16:21 pm by ogden »
Offline ogden
  • Country: lv
« Reply #91 on: November 14, 2017, 08:13:47 pm »
Sorry, I had to correct misleading information Hero999 provided here - regarding LED bulbs on square wave supply.
AC line? Do you have "pure sine wave" inverter? Please show it's output waveform on the scope so we all know what you have.
  • Country: in
« Reply #92 on: November 18, 2017, 05:22:44 pm »
no issue . I hope to know additional possibilities .
Q.Will the driver less LED help me to cut power usage
Offline ogden
  • Country: lv
« Reply #93 on: November 18, 2017, 06:39:22 pm »
Most likely not. If driver-less bulbs would be universally more effective- they would dominate market, but this is not the case. All the hi-end LED bulbs are equipped with some kind of driver. Anyway you shall not rely on assumption. Better search internet for research/reviews which are comparing consumed power versus light output.
  • Country: in
« Reply #94 on: November 18, 2017, 07:52:07 pm »
i was asking  if i use AC MUX
Offline ogden
  • Country: lv
« Reply #95 on: November 18, 2017, 08:25:07 pm »
AC mux will unlikely change anything regarding various LED bulb efficiency. Frequency of supplied AC voltage instead can change a lot. If you use bulbs at much higher frequency - you are on your own. You shall get precision LUX meter and do your own efficiency measurements for various types of led bulbs.
The following users thanked this post: dave_j_fan
