Yes, as @gxti says, you are in that akward region where your picoPSU wants "regulated 12V", but your vehicle supply could range from 10V to 16V (at extremes). So you need something specifically designed to handle the "hostile" vehicle power environment. Been there, done that, not worth "hacking it" when the proper solution is available.
