Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Delete Delete Delete
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Delete Delete Delete (Read 1970 times)
The_Almighty_Bacon_Lord
Contributor
Country:
on:
February 24, 2016, 10:00:11 pm »
Last Edit: August 16, 2020, 06:38:05 pm by The_Almighty_Bacon_Lord
Logged
michaeliv
Frequent Contributor
Re: 2A 5V Single Battery?
Reply #1 on:
February 25, 2016, 12:19:58 am »
Converter:
http://www.ebay.ca/itm/-/281291753628
Or find a similar, more powerful one.
As for if you can drain that much without damaging it it depends on the battery. You need to draw ~3A from it, it should be fine with most cells. Every battery comes with a 'C' rating, Multiply capacity by C to get max current draw. Ex 2200mah * 1.5C = 3.3A max draw.
Logged
michaeliv
Reply #2 on:
February 25, 2016, 01:09:14 am »
Oulps, you actually want a complete USB charger module that would both charge the LI-ion when supplied with 5v and output 5v when working on batteries ?
The link I provided only does the latter half ( it outputs 5v when supplied with input voltage from the battery ).
Simply connect the battery to the input, adjust the potentiometer so the output shows 5v, and proceed to draw 2A @ 5v.
If you want a complete solution the cheapest way to go is to re-use the internals from this (It claims to output 2A) :
http://www.ebay.ca/itm/-/331643918661
http://www.ebay.ca/itm/-/401045504413
Last Edit: February 25, 2016, 01:11:33 am by michaeliv
Logged
michaeliv
Reply #3 on:
February 25, 2016, 04:08:32 am »
I assume that "LiPo" is a typo since I haven't seen a 18650 LiPo cell, only LiIon.
You can use the first link too, even though it uses 4 batteries they are wired in parallel so it's the same as 1 single cell.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
