Author Topic: 2 pole, 2 way switch question  (Read 1011 times)
Offline Chris Wilson
  • Race car engineer, dog lover, hoarder.
« on: November 04, 2015, 11:28:02 pm »
I have 2 server power supplies, 50V at 73 amps each. Outputs are isolated from ground. I want to put them in a cabinet and have a high capacity switch to change their outputs from parallel to series. I want to use a 2 pole, 2 way switch for this, but suitable amperage ones are hard to find. The schematic I will work from is attached. Can I use this Ebay sourced switch, or even cheaper, use two double pole 100 amp mains isolation switches bought separately (for a lot less) with their toggles bridged together and mounted on a common DIN rail, with (and I think I would need to do this...) one mounted upside down??
http://www.ebay.ie/itm/CHANGEOVER-SWITCH-GENERATOR-TRANSFER-125-AMP-1-SINGLE-PHASE-DIN-RAIL-COSDIN-/281692272367?hash=item41962af6ef:g:0HwAAOSw9N1Vk9GR
Thanks!
Best regards,
                 Chris Wilson.
Online Ian.M
Re: 2 pole, 2 way switch question
« Reply #1 on: November 04, 2015, 11:51:56 pm »
No.  Its contacts almost certainly aren't designed to clear a 50VDC high current arc.
You need a switch  rated for at least 120V 100A DC  (120V because it has to clear the arc when the PSUs are in series)
Try googling: 100A DC knife switch DPDT
« Reply #2 on: November 05, 2015, 12:03:49 am »
Ahh, OK, thanks, but would it be OK if no live switching was done? I cannot foresee a time when i would want to go from series to parallel or vice versa with the supply feeding a load.
Best regards,
                 Chris Wilson.
Online Ian.M
« Reply #3 on: November 05, 2015, 12:40:12 am »
Not OK, but it can carry the current and withstand the voltage.   If you are lucky, it might even survive operating under moderate load a few times.   However its an electrical fire waiting to happen unless you can rig an interlocked cover that shuts down the PSUs before anyone can access the switch.
« Reply #4 on: November 05, 2015, 12:58:46 am »
OK, got you, thanks for the warning, I'll probably look for a knife switch, but only I will be operating it, and all the big knife switches seem to be in China, much appreciated Ian!
Actually they do an enclosed one, I could put a microswitch on the cover and have it run a relay on the input side, I have some BIG relays... Cheers.
Best regards,
                 Chris Wilson.
