Could you guys please explain why it would wreak havoc on the power distribution lines, and on other things like wifi? My guess was that maybe it weakens the top half of the AC sine wave, causing an imbalance, which causes other devices on the same line to get imbalanced power? And maybe the imbalance also creates a large electromagnetic field around the device, messing with some wireless stuff and inductive loads?
The heater originally comes with 2 different kinds of controllers (the first 2 in the list below), and I was wondering if you guys could please share your opinions about which of the following methods you think is safest in terms of interference with other devices:
1) Zero-voltage switch triggers a triac. The timing is dependent on an analog pot and a thermistor.
2) A thyristor adjusts the firing angle of the wave, control is by a single analog pot. The heaters with this method seem loud, making buzzing noises when not on full power. Also I've had interference problems with this method, with nearby lights flickering or dimming depending on the heater's setting.
3) Half-wave rectifier diodes to dim the power to about half.
Also, is there another common dimming method for high-power resistive loads, or is it that the first 2 are by far the most popular?
Edit: Also I guess another method was already mentioned above by radar_mcgyver: To use a pwm signal to control an SSR that has an in-built zero crossing detector. But technically that would affect the power in exactly the same way as method #1 above, right?
